this guy seems to be giving pretty good deals. good parts too in his engines. http://stores.ebay.com/P-A-R-E-Race-Engines_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
Allcarfan's pricing is pretty close to correct, but lets not forget, timing chain, timing cover, eccentric, thrust plate, lifters, spider, oil pump, oil pump shaft, water pump, thermostat housing and thermostat, flexplate damper and pulleys, ARP bolts. By the time you add all the little goodies individually, you're near 8K. A near long block is like a near miss; have everything spelled out.
All your "extra" parts are stuff the rest of us collect from various engines and save for future builds, most don't wear out and are completely reuseable.
Hey Bullitt- what kind of power is your combo putting out??
) but since he was quoted $8300 for a long block less those 4 items; if you take the items from allcarfan's list and add for the missing pieces you get real close to 8K. With quality parts and a reputable builder, that's not a totally "unrealistic" price for a stroker. You can buy for less, sometimes you get what you pay for though.All your "extra" parts are stuff the rest of us collect from various engines and save for future builds, most don't wear out and are completely reuseable.
Exactly....and I never buy new unless I absolutely have to. If an engine is brand, spankin new...and a TURNKEY ENGINE...100% complete....I can see $8000. Remember though, the parts we are paying retail for, the builder is probably getting much cheaper. I sitll like the aluminum headed GT40 crate motor that makes 340hp with the right induction. With a different cam and a head port, that engine is a great bang for your buck!
I have less than $3300 in my engine....
331 stroker - ross pistons, eagle Hbeams, hawks racing crank ($600)
DSS girdle and windage tray($150)
Chromoly rings($35)
Bearings ($25)
Twisted Wedge Heads...mildly ported($900)
Scorpion Roller Rockers($100)
Xe274HR comp cams cam($150)
Ported RPM intake($75)
Cobra finned valve covers($45)
high flow water and oil pump($150)
Timing chain cover with pete jackson noisy gear drive($150)
chrome oil pan($65)
Assembled and balanced/machine work($500)
Chromoly pushrods($65)
spider/hold downs/lifters($75)
Gaskets ($150)
Roller BLock...$50 (junkyard)
I still need a carb though and I am sure I missed a part or two. So, lets conservatively say...$4000 into the engine...built for a small shot of nitrous and...hopefully...will make 325+ at the wheels with no bottle.
Maybe I'm trying to have my cake and eat it too...but all I want is a supercharged 302 block that pushes 400+rwhp and that is great to drive on the street (leave the suspension/braking/steering issues out as I will work on those most definitely)
Great to drive on the street means:
- 12+mpg city... 15+highway (keep in mind I will be running Ford EFI)
- Never dies on me
- Never overheats in the worst of stop-and-go traffic
- Drives well in any RPM
All these parts discussions and price variations are making me nuts!! I want AFR heads, a Kenne Bell supercharger, a mild cam with a slight lope, and EVERYTHING ELSE figured out. Maybe I'm lazy.
On another note, I must look/sound like a sucker to these engine builders... they are sure quoting me high prices.
- Never dies on me
In the Ranger with a Toploader 4 speed, 3.73 rear with 28" tires it got 12 mpg with my foot in it and 16 driving conservatively on the highway. Power came in at 1500 and pulled like a freight train to 6500. I believe Keith Craft puts out a budget stroker for mid $5K last time I looked, but the word "budget" just makes me cringe when I think of something that high of HP made "less costly". It just brings to mind the motor grenading the first time I hit 6500 going down the straightaway or flooring it just after a turn.![]()
