  • SN95 4.6L Mustang Tech
Engine "rattle"
  • Thread starter Thread starter Lost Time
  • Start date Start date Jan 29, 2007
  • 3
First Prev 3 of 3
L
Lost Time
14
#41
  • Feb 6, 2007
  • #41
I'm in Birmingham, AL. I'll check tomorrow about the rental of equipment.
Yeah, I had somebody cut open the last oil filter that came off and they said it was clean. There doesn't appear to be any loose metal in the oil. So at least nothing is coming off in pieces........
Is it possible that one of the valve springs is "loosening-up" once it warms up, or is that not possible? Also, does the fact that it doesn't make any noise under load OR deceleration give any clues to what it might be? The fact that it only does it under netural throttle or very light acceleration and in a fairly narrow rpm-range, should be suggestive of something I would think.
M
Muscle99
48
#42
  • Apr 11, 2007
  • #42
did you find anything out about this. Im having the same problem with my 99. Seems to run fine but when the engine is cold and i get to about 2k RPM it makes that same racket. When it warms up the sound deadens some but its still there. Sounds like its coming from the same spot yours is. IM talkin about your racket sound only.
BannonJr
215
St.Lazare Quebec
May 14, 2007
#43
  • May 14, 2007
  • #43
I gots a rattle also that I can't figure out...I'm opening the engine up to take a peek at the timing chain / tensioner....with a stethiscope...I think (not sure) hear the rattling from down near the timing chain...and maybe a grinding? Could just be the sound of the chain though. I changed the tensionser pulley, didnt help...
I have no loss of power at all...nothing has changed with performance...
I got one week to figure it out and fix it...I'm driving from Montreal to Indianapolis...not a good idea to travel that far w/ a rattle I think.
Advinnie
Oxfordshire
Dec 2, 2019
#44
  • Dec 2, 2019
  • #44
Old thread I know but did you ever find the problem, did you find out what was causing the noise?
  • 3
First Prev 3 of 3
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
