Engine rebuild advice please
Their are 2000+ engine that sell on ebay for 1k with 70k+ miles. Can it fix my 98gt ? my tranny is grind in reverd , but if I put in 4 then rever it will not grind, should I replace the tranny too ? and my clutch is vibrate, its good ideal to to king cobra at the same time ? thanks
Not worth the money.
1) You don't know what kind of shape the engine is in
2) you can buy a brand new shortblock from MMR that can with stand 500+WHP for $2700
What is short block and long block ? I email MMR and here what they tell me
New forged pistons, moly faced rings, headgaskets and machine work will be roughly $1400, we also have brand new factory shortblocks or longblocks, the shortblocks are $1999.99 and the longblocks (265HP) are $2699.99, these may be a better alternative for you.
MMR
If I buy short block, what part from my 98gt will need ?
If I buy long block, what part from my 98gt will need ?
My engine have worm ring and stuff ? what its best for me ? my local shop charge me 1200 for take out the engine and put the new one it, that just the labor.
short block: block with pistons and crank installed.
long block: short block, plus heads, timing components and oil pump.
with a long block you'll have to re-use your front end accessories, intake and exhaust manifolds, cam covers, oil pan injectors and the like.
with a short block all that plus the timing gear, heads, front cover and possibly the oil pump
IMHO getting just a short block for a Mod motor doesn't make much sense unless you plan on doing the hardest part of the engine build yourself or you already have some nice heads or something like that :shrug: ...but again IMHO, you're probably better off following the recommendations of someone like MMR than random dudes on the interweb :rlaugh:
The hardest part of the engine build?? You mean installing the heads ??:rolleyes:
That would be cake compared to installing the crank, bearings, pistons, rods, rings, and that other sh1t. Plus if they aren't to spec, it'll knock, and become worthless. IMO a shortblock is a great choice for someone who wants to save some cash....
