Engine Restorer?
  • Thread starter Thread starter Cavcloser29
  • Start date Start date Jan 26, 2004
  • 3
1 of 3 Next Last
C
Cavcloser29
22
Akron
Jan 26, 2004
  • Jan 26, 2004
I've heard alot about this "Engine Restorer & Lubricant" by Automotive Restore Products--- Does this stuff really work, or is it bad news for an engine? (also what about the 2 in 1 fuel cleaner?) I need some help.
C
Cavcloser29
22
Akron
Jan 26, 2004
  • Jan 26, 2004
Anybody got the lowdown on this stuff?
FiveOhhStang
299
Sanger, Cali.
Jan 26, 2004
  • Jan 26, 2004
From what I have heard, its like Pooring a can of Vasoline in your motor, is makes everythng 'act' newer and better, and seals rings for a bit, BUT I did it before I heard that...Its bad news, 1 major problem is that it clogs your oil pump sometimes....Plain and simple DONT...no Oil additives just run 20-50w if your buring oil, I do it to be safe, and at most youll lose 1hp on a very very bad day in hell.
-Nick
C
Cavcloser29
22
Akron
Jan 27, 2004
  • Jan 27, 2004
Thanks alot pal, I'll stay away from it
HISSIN50
34
129
Jan 27, 2004
  • Jan 27, 2004
i dont know about the vaseline analogy. the lucas stuff is reportedly like that (like the oil "honey" we used to use way back when). ive used restore (no differences noticed), and my observation was, relative to most additives, it's pretty viscous, IMHO.
the only real bad thing to use is anything with teflon, or any other crud that doesnt belong in motors. if its burning or leaking so bad that 20-50 doesnt help, fix it. just my two cents worth.
FiveOhhStang
299
Sanger, Cali.
Jan 27, 2004
  • Jan 27, 2004
If you want a 'Restorer' for performance or for better engine output...I would stand by saying up the wieght on the Oil 20-50w made my car smoother, and it helps with compression too(what that restorer tries to do inorder to give you 'the lost horsepower') If that doesnt help, like HISSIN50 said, fix it.
-Nick
P.S. Mobil 20-50w is what I use..i think its with that 'Cleaner' crap or whatever, blue bottle..
HISSIN50
34
129
Jan 27, 2004
  • Jan 27, 2004
the whole sales pitch with restorer is that its supposed to fill the scratches in the cylinder walls. i dont see that happening. and if it did, what about cross hatching. does it supposedly fill that too. i dont buy it.
i am one whom runs 20W-50 9 months of the year (ambient temp ranges from 80-110). older mills have more tolerances than fresh mills. when they get some miles on them, i see no reason not to run higher viscosity oil in them, esp if you see extreme conditions.
another way to look at it is that if 10W-30 or 5W-30 is good for the coldest temps imaginable, then one could reason that 5-30 flowing at start up in 0*F would flow no better than 20-50 at 90*F.
you really want the thinnest weight you can run that keeps pressure at the most extreme condition your motor sees, unless you are compensating for other issues.
CC29, what is wrong with your motor? might be of more assistance if we know what is up.
C
Cavcloser29
22
Akron
Jan 27, 2004
  • Jan 27, 2004
Nothing is wrong, its just that my motor is approaching 90000 miles and I wanted to know if there's anything that I can put in it to release all that lost power.
whitemustang89
166
in the sticks of arkansas
Jan 27, 2004
  • Jan 27, 2004
90,000? **** i have about 155000 and mine still runs like a raped ape
IndyBlk5.0
1,122
New Whiteland, IN
Jan 27, 2004
#10
  • Jan 27, 2004
  • #10
i dont think you will notice any difference with an oil additive... i wouldnt ever use an oil additive. different weights for different seasons, if you are really worried about it, switch to synthetic oil, mobil 1 is the best. but its really expensive. no noticeable power gains from that either =) if you want power gains, just get a good o/r h pipe, and a good flowing catback, good investment...
sixty9boss302
234
Pittsburgh PA or Rochester NY
Jan 27, 2004
#11
  • Jan 27, 2004
  • #11
CC29, i have used the 2 in 1 fuel system cleaner and i was surprised at how well it worked. Its cheap and it works great...toss it in an empty tank every time u change ur oil and u'll b good.
R
RickyB
592
NJ
Jan 27, 2004
#12
  • Jan 27, 2004
  • #12
90000 miles........your car is still a virgin
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jan 27, 2004
#13
  • Jan 27, 2004
  • #13
wow...that has to be one of the funniest things ive ever heard. but anyways..mine has 191k on it and the motor has never been opened up for anything, and it runs like a champ....ive got a few little oil leaks and a trans leak....anyone know of anything to help that out
cevtv
1,113
Massachusetts
Jan 27, 2004
#14
  • Jan 27, 2004
  • #14
Find the leaks, and fix them. Don't put a band-aid on it, fix it and don't worry about it again.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jan 27, 2004
#15
  • Jan 27, 2004
  • #15
alright...sounds like a plan to me....do i have to pull the motor to do a oil pan gasket?
sorry, kinda stole the thread
HISSIN50
34
129
Jan 27, 2004
#16
  • Jan 27, 2004
  • #16
ECU, it is said to be best to pull it, but someone did a thread about how he did his easily without yanking it. i would take some perspective (mine.LOL). if it has almost 200K on it, at some point in the not too distant future, chances are something will need to be done to the motor. were it me, unless the leaks are horrible, i would leave them alone. hate to do all that work, and then not long afterwards, pull it all to do some engine freshening. just my thinking.
good advice on the fixin of leaks. if it leaks, manually fix it. no snake oils.
siege
651
Peoria, AZ
Jan 27, 2004
#17
  • Jan 27, 2004
  • #17
hmmm....so does that mean no stopleak then? I used some a few oil changes ago and stopped using so much oil between changes, leaks went away and I'm noticing less metal shavings in the oil than previously (yeah, I know that's bad - I'm workin on it). if I shouldn't have used it...oh well
HISSIN50
34
129
Jan 27, 2004
#18
  • Jan 27, 2004
  • #18
my two cents worth:i dont have a problem with the stuff, as long as it doesnt have teflon (teflon clogs things up top). i have used the stuff a lot on all cars throughout the years. i dont see it doing any real harm.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jan 27, 2004
#19
  • Jan 27, 2004
  • #19
yeah, im probably gonna wait until summer to take the engine apart
C
Cavcloser29
22
Akron
Jan 27, 2004
#20
  • Jan 27, 2004
  • #20
Thanks for all your help. I appreciate it . I think i'm gonna go with either Mobile 1 or Royal Purple.
  • 3
1 of 3 Next Last
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
