  • SN95 4.6L Mustang Tech
Engine Revs but doesnt move fast...Clutch or Trans??
  • Thread starter Thread starter 97GTSTANG
  • Start date Start date Oct 4, 2011
97GTSTANG
852
Virginia
Oct 4, 2011
  • Oct 4, 2011
When i am shifting from 1-2 and 2-3 i will floor the gas with my foot off the clutch and the RPM will climb to 3,4,5K RPM but the car will just rev and but not as fast.
The clutch is very high. its a spec 1 clutch. Its over 5 years old, not sure if that has anything to do with it?
Any suggestions?
trinity_gt
3,125
81
99
Canada
Oct 4, 2011
  • Oct 4, 2011
Pull the trans and replace the clutch. You're likely in for a flywheel or resurfacing depending on how much heat damage there is from revving to 5000RPM with the clutch slipping like that.
In the process of putting a new clutch in it inspect and replace if necessary things like the clutch cable, release arm, pilot and release bearings, release arm and pivot, input shaft retainer (the sleeve over which the release bearing rides) etc.
97GTSTANG
852
Virginia
Oct 4, 2011
  • Oct 4, 2011
So you are saying the clutch is slipping? will that make the car lose power? Because i just completed the PI headswap with comp cams 262. It doesnt feel very strong at all but i was thinking it was because of the clutch. What do you recommend for a clutch replacement? so the flywheel is different from the clutch?
apats77
178
Watertown, MA
Oct 4, 2011
  • Oct 4, 2011
I recommend the SVE mongoose or the Ram HDX. For a flywheel go with the Ford Racing Nodular
1996-00 Mustang GT Nodular Iron Flywheel, 164 Tooth - 10.5" 6 Bolt, M-6375-D46 at LRS - Same Day Shipping!
1986-00 Mustang SVE Mongoose Clutch Kit, 10.5" 10 Spline for 5.0L & 4.6L at LRS - Same Day Shipping!
1986-00 Mustang Ram Hdx Clutch Kit, 10.5" 10 Spline for 5.0L & 4.6L at LRS - Same Day Shipping!
^ a bit tougher then the goose
Would you agree Trinity?
D
Deleted member 38176
Oct 5, 2011
  • Oct 5, 2011
Lose power to the wheels? Yes. The engine is making the power it should but it is not being transfered adequately to the drivetrain, a lot of it is lost through the slipping clutch. It's a pretty simple concept to grasp if you think about it.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Oct 5, 2011
  • Oct 5, 2011
More than likely, the clutch is toast. Get a new flywheel with clutch. A good time to get rid of your shorty headers since they add no power and add longtubes, even if you go with the cheaper flowtechs. Make sure you RTV the flowtechs since they slip on.
txredgt
1,343
33
69
Oct 5, 2011
  • Oct 5, 2011
I'd say if you got 5 years out of your spec stage 1 stay with it. That is what I just put in after my stocker went 90K.
Stumbaugh
903
Russellville, Ar
Oct 5, 2011
  • Oct 5, 2011
Centerforce Dual Friction clutch FTW!
D
Oct 5, 2011
  • Oct 5, 2011
It's situations/threads like this that I am so happy I have an auto. Clutch & flywheels replacement = PITA x 10!!!
Stumbaugh
903
Russellville, Ar
Oct 5, 2011
#10
  • Oct 5, 2011
  • #10
I can have my car jacked up, and trans sitting on the ground in 1 hour with a friend helping...It's not to bad.
trinity_gt
3,125
81
99
Canada
Oct 5, 2011
#11
  • Oct 5, 2011
  • #11
BUT it must also be said that this is a price worth paying for 0.01% of the time when 99.99% of the rest of the time is spent banging the gears yourself instead of letting the PCM do it for you
Admin Dude
Jan 4, 1985
43,564
21,735
234
Box behind Walmart
Oct 5, 2011
#12
  • Oct 5, 2011
  • #12
Any suggestions?
Clutch ain't the only thing that's high... replace it.
97GTSTANG
852
Virginia
Oct 5, 2011
#13
  • Oct 5, 2011
  • #13
Will these work together? Will they work with my stock transmission? Thanks again guys
RAM HDX Clutch (86-Mid 01 Mustang GT and 93-98 Cobra) at AmericanMuscle - Free Shipping!
The prices seem right. Or is there a less expensive flywheel you all can think of that is good? Can they resurface the flywheel i have to save on that?
Thanks
Do you all recommend a new clutch cable / I want the pedal to be lower to the floor.
97GTSTANG
852
Virginia
Oct 5, 2011
#14
  • Oct 5, 2011
  • #14
I will like longtubes but i do not want to purchase a new catback exhaust to fit the longtubes. I just did the PI headswap stage2 and comp cams. i am tapped out on cash.
apats77
178
Watertown, MA
Oct 6, 2011
#15
  • Oct 6, 2011
  • #15
Those should go together fine. you might as well order the clutch from LRS too because you are paying the 15 buck shipping for the flywheel already and the clutch is a bit cheaper then AM.
97GTSTANG
852
Virginia
Oct 6, 2011
#16
  • Oct 6, 2011
  • #16
thanks for the tip. i will go ahead and order those items. i just hope that solves the problem.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
  • Gulftown980x
  • Jul 29, 2026
squeak93
