  • SN95 V6 Mustang Tech
Engine revs itself in neutral? Help please.
  • Thread starter Thread starter gian2oo1
  • Start date Start date Sep 15, 2005
G
gian2oo1
  • Sep 15, 2005
Hello. I have a completely stock 2001 v6 5speed mustang (except I put a k&n air filter in and new plugs (i dont know if I torqued them correctly though)). Sometimes when I push in the clutch the engine revs itself to 3000 or 3500 rpms. then if I brake and completely stop then the engine will go down normal. Do you know what might cause this? The car has 56,500 miles on it. If you need any more information please ask. Thanks a bunch,
~Gian
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Sep 15, 2005
  • Sep 15, 2005
K&N got oil on your MAF, perhaps. Check the MAF sensor and make sure it's not covered in oil. Let us know.
G
gian2oo1
  • Sep 16, 2005
Hi,
I checked the MAF sensor. It is completely dry and there is no oil anywhere.
timeless2
Admin Dude
202
154
the Shadow Gallery
Sep 16, 2005
  • Sep 16, 2005
Have you tried resetting the PCM? Disconnect the battery for about 15 minutes or so, then reconnect it.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 17, 2005
  • Sep 17, 2005
look at the IAC
timeless2
Admin Dude
202
154
the Shadow Gallery
Sep 17, 2005
  • Sep 17, 2005
tomustang said:
look at the IAC
IAC's suck on sixer's, too?
G
gian2oo1
  • Sep 17, 2005
Hello!
I reset the PCM but it didn't help. The engine still revs itself high when I push the clutch in.
tomustang said:
look at the IAC
The IAC looked a little dirty (the peices that I thought were steel were a darkish brown colour. I cleaned it with carb cleaner and ran the car around the blocked a few times. It didnt rev when I pushed the clutch in, but I only had it out for a few minutes. I'll know for sure if it was the IAC during my commute to work monday.
___________________________________________________
Also, I found a wire that was not connected to anything. Should this be connected to the battery? It was just hanging over the windshield fluid cap when I popped the hood. It is a red wire with what looks like a green fuse on it. Here is a picture of it:
And here is a picture of the fuse that is lead off of the wire:
Thanks for helping I appreciate the responses!
~Gian
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
T
Newbie here with an odd story
  • thequadfather
  • Jul 20, 2024
  • The Welcome Wagon
The Welcome Wagon Jul 22, 2024
thequadfather
T
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 16, 2024
89ripper
