- Sep 9, 2004
- 3
- 0
- 0
Background: Car stalled intermittantly and sometimes would not start. I replaced each item and test drove for a week prior to replacing the next item.
This has been corrected by replacing the following in order:
1. New Plugs and wires
2. New ICM
3. New Coil
4. New MSD Distributor (I am convinced the stator failed when it heated up)
Now I installed the distributor but have bad pinging at high RPMs and sometimes low RPMs if the automatic is in OD. I run 87 octane.
The timing was adjusted by the Ford dealership but the initial timing could not be acheived. It's running better, but not 100%.
Could the distributor be installed (1) tooth off? I wouldn't think that matters?
The car has no mods and is a stock 5.0 automatic.
2. New ICM
3. New Coil
