Engine swap - Intake Height Problems
  • Thread starter Thread starter KiwiGT
  • Start date Start date Sep 23, 2007
K
KiwiGT
95
Australia
Sep 23, 2007
  • Sep 23, 2007
I am currently installing a roush 342 crate engine in my '66, along with a T5. The crate engine has a Canton sump, and a Vic jr / holley street avenger 770cfm, MSD distributor.
On a trial installation the sump is clearing the drag link by about 1/4". Using a 1 3/4" drop base air cleaner, and a 2" filter element, my air cleaner is sitting about 1/2" higher than the fender line, meaning I won't be able to close my hood.
I can't drop the engine lower or I'll hit the drag link. As far as I can see, my options are a bigger drop base on the air cleaner, or changing to a lower height dual plane type mainfold.
Will changing to a dual plane manifold lead to performance or tuning issues given this crate engine was built by Roush as a single plane engine ?
Any other suggestions or knowledge of drop base air cleaners to help me out ?
TIA
BornInAFord
199
Bend, OR 97701
Sep 24, 2007
  • Sep 24, 2007
The center of the stock hood peaks above the fender line more than a half inch--your clearance might be fine, but you'll only know by installing the hood. You might need to use a shorter air cleaner bolt and wing-nut, however. I think going to a shorter intake would lose you some of the power you paid good money to get.
Daniel
CraigMBA
783
Orange, CA
Sep 24, 2007
  • Sep 24, 2007
You can't run the 2" element with an 1 3/4 drop base. The choke will never open past the air cleaner lid. You'll have a two barrel.
I would reinstall the engine and the hood. Then, using Play Doh or some other type of modeling clay, figure out how much clearance you actually have between the carb and the hood with it closed.
fasttback
471
Northern CA
Sep 24, 2007
  • Sep 24, 2007
Yes the centerline of the hood is above the fender height - you might have enough clearance. I'm using a Victor Jr. on my 302 stroker in my 1966. I do have a Shelby fiberglass hood, but I'm not using a drop base air cleaner = very tight fit.
Beside the air cleaner change, another expensive option is to go with an aftermarket hood with a scoop.
K
KiwiGT
95
Australia
Sep 24, 2007
  • Sep 24, 2007
Daniel
I trial fitted the hood and you're right - there's a good 1/4" to spare - I don't know what I was worried about
Thanks for all the replies and assistance
MustangMatt1966
1,004
Orlando Fl.
Sep 24, 2007
  • Sep 24, 2007
I had a similar problem, but used it as a good excuse to get a 2.5 inch cowl hood
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Engine 5.0 HO carb air cleaner question
  • nothwoods
  • Nov 27, 2024
2K
Fox 5.0 Mustang Tech Mar 23, 2025
General karthief
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
