  • SN95 4.6L Mustang Tech
engine swap question
  • Thread starter Thread starter happydood2
  • Start date Start date Sep 9, 2004
happydood2
81
MA
Sep 9, 2004
  • Sep 9, 2004
I have a 98 mustang gt and i want to swap the engine for a 2003 mustang gt engine and was wondering if everything would work out. I was going to just do the pi swap but my engine burns oil and i want a low mile engine. Also im going to supercharge it later and dont want to worry about compression. Will the engine bolt up to my tranny. Is there anything i need to know about doing this.
happydood2
81
MA
Sep 9, 2004
  • Sep 9, 2004
anyone??????
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 9, 2004
  • Sep 9, 2004
engine will bolt up to the trans. there will be wiring harness issues, and you have to use your stock fuel system, or else reconfigure your car for a returnless system.
Trick98GT
246
Pensacola, FL
Sep 9, 2004
  • Sep 9, 2004
i swapped in a motor out of a 99...Everything goes in smooth. You just have to reuse all of your accessories(alt, water pump, fuel rails, etc.). Your computer cant run the COP ignition system, so you have to keep the 2 coils. Basically just use the new longblock (block and heads) and put everything else back in just the way it was.
ChadS98GT
1,924
Parker, CO
Oct 30, 2004
  • Oct 30, 2004
sorry to bring this back from the dead....
but we can just reuse our fuel setup from the 98GT onto a newer PI engine....also what about the trannys will our T45 bolt up ok??
What did you do about the wiring harness issues??
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 30, 2004
  • Oct 30, 2004
reuse your fuel set up and just get a chip or programmer custom for the swap so it will run better but should run fine regardless ... only thing that you will have to really worry about is tapping the intake for the extra coolant sensor on the intake ... some have swapped aluminum cross over housings ... not sure how though ...like the other guy said just look at it as a standard longblock and keep all the accessories brackets , fuel system etc ..off your old engine and you should not have any problems
ChadS98GT
1,924
Parker, CO
Oct 30, 2004
  • Oct 30, 2004
thanks..
for those that have done this swap....about how long did it take?? i am trying to get an idea of the time frame my car will be down.....trying to minimize it as this is my daily driver.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
