Engine swap question
DanMan136
Hello, I have a 1996 mustang GT. All stock except for exhaust. Automatic. I am getting up there in miles on the stock engine. I want to swap out with a 2001 DOHC cobra engine or a 2003 DOHC SC cobra engine. my question is how hard would it be to swap either one of those engines into my car? thanks in advance for any info.
Gearbanger 101
Straight Outta Locash
9,457
1,378
234
Ontario, Canada
The answer is.....very. Not impossible, but if you're approaching this with next to no automotive experience what so ever, you might want to rethink the decision and just go with a late model PI engine to boost your stock performance. It’s pretty much a direct swap.
SonicStangGT
146
King, North Carolina
It should not be that hard. You would need motor of course, ecu, wiring harness are the main things. There would other things you will need, different headers if motor has none, mid-pipe should bolt to sohc or dohc models. You might have to change motor mounts. Your tranny should bolt up. Not 100% sure on everything, but most all the mustangs with sohc or dohc 4.6's 96-04 are pretty much the same under the hood(other thatn different motors and trannys). The swap would be like installing a new motor. Everything should bolt right up. Good Luck.
Bolt right up :rlaugh:
rugster
156
Bolt right up? Not a chance...
Think about all the throttle linkage, that fact that the instrument cluster runs mechanically in a 96 and electrically in anything 99+ for mileage and speed purposes. There are numerous sensors that the newer motors have that the older ones didnt. My advice is to do as I did, get a new PI motor, pretty simple swap. But don't do the cobra swap, unless you have patience and fabrication know-how. Good luck:nice:
BurningRubber
1,865
24
58
If you want a nice power boost and your engine is in GOOD mechanical condition just supercharge/turbo it. I know you said high miles, but those are just numbers.
By the time all the cost adds up to swapping either one of those Cobra engines you will be able to have bought some kind of forced induction kit. You can make decent power even with your engine.
If your engine isnt in the best shape, perhaps a PI (99-04) engine like the others suggested. The car wont be a rocket but it will be a nice improvment, and if you get a new or lower mile engine that is in good shape you can throw some boost at it later on down the line.
Now, if you have your heart set on a Cobra swap, by all means go for it. It is just a headache and it wont be cheap in the end.
SonicStangGT
146
Yeah, I'am not hard, OPPS, My bad centennialstang. I guess it would'nt be that bad for someone with experiance and if you didnt have any it would be impossible. But if you have your heart set on a cobra motor, I would try to find a donar car to get parts from.
mransr
1,188
36
98
Riverside, SoCal
I suppose "bolt right up" is in the eye of the beholder ;)
putting a DOHC in a SOHC Mustang doesn't require any real fabrication as it's an engine that was offered in a Mustang...it just requires finding ALL the right parts (and there are a lot of different ones) and/or some modification of current parts to work with the new engine...
I mean it's not like putting a 351 Cleveland in a 66 Mustang or a 390 in a 56 F-100 or a BB Chevy in a 41 Willys Pick-up....those are the sort of swaps that I wouldn't consider "bolt-ins"
