  • SN95 4.6L Mustang Tech
Engine Swap...
  • Thread starter Thread starter edothekid
  • Start date Start date Mar 22, 2004
E
edothekid
165
California
Mar 22, 2004
  • Mar 22, 2004
Hey Guys,
Well, I just bought a 2001 4.6L engine with 44,000 miles on it.
I am going to swap it for my 1996 4.6L engine with 134,000 miles on it (started to smoke)
Now, the question is what should I buy or need to prepare for besides the direct swap.
This is what I know so far...
1. Use my existing fuel rails...ect...
2. Use my existing coil pack and brackets...
3. Find a place to tap the second temp sensor or use the "T" method..
Thats it, this is all I know of that has to be changed besides just directly swapping the engines.
Is there other stuff I should know before I start the swap.
I have read threads about the timing cover issue because of the belt routing interfering with the coil packs, also about the water pump being different.
Does anyone have a write up or knows what is involved in doing the swap.
Please advise, any help will be greatly appreciated.
Thanks again,
Edo.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 22, 2004
  • Mar 22, 2004
sounds like you got it covered , if you have an aluminum crossover on your intake , just swap it onto the PI intake and you should be good to go . use your fuel rails , might wanna use the newer injectors off the other engine if you have them though , and use your old brackets etc for your coils and such .
E
edothekid
165
California
Mar 22, 2004
  • Mar 22, 2004
Yes, I do have an aluminum crossover on my old non pi intake that is currently on my car. Can I swap just the aluminum piece onto the new P.I intake?
So, the injectors on the new motor are the same as the ones currently on my 96?
Also, I have a C&L MAF kit which was bought for my 1996 GT.
Could I use this kit on the new motor?
starkie
1,234
South Jersey
Mar 22, 2004
  • Mar 22, 2004
You can use your C&L meter still. And the timing cover from the 96 should be transfered over to the new engine, you are right about the interference.
You don't need a writeup man, you got everything covered. What are you waiting for....lol
Good luck man!
Starkie
E
edothekid
165
California
Mar 22, 2004
  • Mar 22, 2004
Good luck man!
Starkie
I know it should be a simple swap right?
Ok, cool. Thanks guys, I'll let you know how it goes.
Also, if anyone knows. What kind of hp numbers or improvement in the 1/4 will I see with the new engine and all the mods listed. I will also have a custom tune done with the diablo chip.
9
96stanglife
26
  • Mar 22, 2004
I just through doing the swap myself...You have everything covered, as far as the temp. sensor, I just tapped into the top side of my thermostat housing..You DO NOT need to swap out your timing chain cover, the holes for your coil pack brackets are still there.....If you have any questions E-Mail me at Yabba75@aol.com
Jason
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
R
Transmission for manual swapping a 1994-1995 GT
  • Rembrant
  • Jul 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 13, 2025
Rembrant
R
P
market for 2.3L? i wanna sell
  • Patk
  • Dec 6, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Dec 7, 2025
rednotch
