engine temp running slightly warmer than usual heater blowing cold
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Hey fellas my eng temp is running a lil on the warm side but the heater blows cold air. I checked to see if I had air in the system, when car reached operating temp the coolant around the radiator neck bubbled some but never "burped" over. When I would give it some gas like 3-4k rpm the fluid would drop and then raise back up. What do yall think is causing the heater to blow cold, heater core, thermostat stuck open?
Check out the heater controls first: make sure the heater door arm is moving. It is cable operated, and the cable may have come off one end or the other.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
