Engine temp sensor
  • Thread starter Thread starter ForceFed70
  • Start date Start date Oct 12, 2005
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Oct 12, 2005
  • Oct 12, 2005
If you had to install a 2nd temperature sensor in your car how would you do it?
T
ttoney
195
Denver
Oct 12, 2005
  • Oct 12, 2005
rectal thermometer in tailpipe? Cruel I know.
shotsy
233
Oklahoma City
Oct 12, 2005
  • Oct 12, 2005
you could tap and thread your upper raidiator hose neck or weld a bung into it?
F
ForceFed70
4,818
BC Canada
Oct 12, 2005
  • Oct 12, 2005
I've been thinking about that, but since it's on the "cold" side of the thermostat I'm worried it won't give the most accurate reading. It won't read true engine temp until the thermostat opens. I guess drilling a small hole in the thermostat might help...
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Oct 12, 2005
  • Oct 12, 2005
What I did was put the more accurate Autometer sender in the intake manifold and the stock sender in the thermostat housing. The only way you'll get an inaccurate reading is if you put the t-stat in backward and it never opens.
F
ForceFed70
4,818
BC Canada
Oct 13, 2005
  • Oct 13, 2005
But won't the guage stay pointing at "cold" until the engine has reached operating temp and the thermostat opens...at which point the guage suddenly moves over to "normal"?
65ShelbyClone
4,675
38
119
Oct 13, 2005
  • Oct 13, 2005
Yeah, but I dont think that would be a problem. I know I wouldnt be real worried if the engine was running cool enough to see the t-stat open and close. If its running too hot, it wont matter since the 'stat will be wide open. The exception would be if it stuck shut and the gage read cold while you were boiling over. If thats a concern, then the thermostat housing wouldnt be the best place for the only gage being used.
F
ForceFed70
4,818
BC Canada
Oct 13, 2005
  • Oct 13, 2005
That makes sence. Problem is that I want to use this temp sensor for my EFI conversion so I need to know the engine temp as acurately as possible.
I suppose I could always use the new sensor for the guage and the old one for the EFI computer.
red65
411
Ann Arbor, MI
Oct 13, 2005
  • Oct 13, 2005
If you're using the stock 5.0L heater hose outlets: One of the heater hoses connects to a steel tube and 90-deg fitting that screws in near the front passenger-side of the intake manifold. I drilled and tapped the top of that 90-deg fitting to accept a sender for my temp guage (1/8" NPT in my case, but there's room for a bigger fitting if need be). So - the sender screws in vertically into the top of that fitting - take a look - you'll see where I mean. The heater hose is, of course, pre-thermostat, so the temp reading isn't dependent on whether or not it's open. It works well - might be a good place for you if you're using a similar setup...
J
jbuening
399
Oct 13, 2005
#10
  • Oct 13, 2005
  • #10
Some run an extra temp sender in the vacuum port on the thermostat housing. Some of the mustangs had dual vacuum diaphragms and had a fitting on the top of the thermostat housing. Get one of those and you'll be golden, or get an aftermarket aluminum intake. The Typhoon intake i have has three temp sender ports.
D
D.Hearne
11,730
south louisiana
Oct 13, 2005
#11
  • Oct 13, 2005
  • #11
I always place the second one in the T-stat housing, that way you know when and if the T-stat is functioning.
F
ForceFed70
4,818
BC Canada
Oct 13, 2005
#12
  • Oct 13, 2005
  • #12
Actually I'm converting my 351W to EFI, but the heater hoses are the same.
I've been considering this... Except instead of drilling and tapping the 90* fitting, I may just swap out the fitting for a "T" style fitting and screw the temp sensor into one end.
Do you happen to know the direction of coolant flow? Some heat will be lost through the heater core so I'd like to be on the "hot side" of the heater core.
F
ForceFed70
4,818
BC Canada
Oct 13, 2005
#13
  • Oct 13, 2005
  • #13
Sorry I'm a little confused. Some 5.0's had vacum ports on the thermostat housing? What for?
And if it's a vacum port, why would I put a coolant temp sensor in there?
D
D.Hearne
11,730
south louisiana
Oct 13, 2005
#14
  • Oct 13, 2005
  • #14
Coolant flows from the intake to the heater, back to the waterpump. Just replace the 90 degree elbow with a Tee fitting.
D
D.Hearne
11,730
south louisiana
Oct 13, 2005
#15
  • Oct 13, 2005
  • #15
That was a vacuum switch on the T-stat housing. The earliest ones switched the vacuum for the distributor ( advance to retard) depending on the engine temp.
F
ForceFed70
4,818
BC Canada
Oct 13, 2005
#16
  • Oct 13, 2005
  • #16
Sounds like this is going to be my best route...
65ShelbyClone
4,675
38
119
Oct 13, 2005
#17
  • Oct 13, 2005
  • #17
Ok, I didnt know you were doing this for an EFI temp sensor. Thats makes it alot easier.
The EFI cars dont have a water valve going to the heater core, so it gets water circulation all the time. EFI cars have metal heater lines that sit behind the passenger side valve cover. The line feeding the heater core from the intake has a bung in it which it where the stock EFI sensor went! The actual sender for the gage just went in the port on the driver's side rear port of the (EFI)intake.
J
jbuening
399
Oct 13, 2005
#18
  • Oct 13, 2005
  • #18
Sorry guess i could have clarified. Some 69/70 (and maybe earlier/later years)302 and 351w motors had the port there. This i guess doesn't help much cause it won't be accurate until the thermostat opens. Just a thought though, as i know some people run the temp guage sender for their factory guage to this port. It still will read coolant temps, but was used i think for advancing/retarding the igntion when the motor was hot. I am not too sure how the port works as far as vacuum goes but i just know people use that port for temp senders.
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
Engine Fan temp sensor location.
  • 7-UP BILL
  • Apr 3, 2026
Fox 5.0 Mustang Tech Apr 7, 2026
KRUISR
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
