Engine tilt question?
  • Thread starter Thread starter Shakin66
  • Start date Start date Sep 18, 2005
Shakin66
628
Waycross, Ga / Lake James, NC
Sep 18, 2005
  • Sep 18, 2005
I am installing a t 56 6speed and I know one of the problems with doing this is the driveline angle being to great causing the engine to lean back to far. I have cut the tunnel and it is currently at 3.5 degrees. I just cant remember if its 3 or 4 that is best and want to mount the crossmember today if someone out there has the answer that is.
G
gsxrken
206
Weschester County, NY
Sep 18, 2005
  • Sep 18, 2005
3 degrees is the stock angle. Use your rocker flange to figure out and control for any rake the car may have in its stance. You'll have to make up a crossmember out of tubing and angle iron etc to hold the trans at that angle. None of the commercially available x-members position the tranny correctly b/c they figure you weren't going to do it right and cut the tunnel. Post some pics if you can!
H
HHStang
566
Coastal SC
Sep 18, 2005
  • Sep 18, 2005
Be sure your rear is angled up at the same 3.5 degrees...
ozstang65
313
Queensland, Australia
Sep 18, 2005
  • Sep 18, 2005
I always thought it was 4°, but in most cases it's whatever angle that causes your carby pad to be dead level. As long as the diff pinion is set to the same angle.
Shakin66
628
Sep 19, 2005
  • Sep 19, 2005
I have cut the tunnel (lost my factory air) and have it currently set at 3.5 degrees. I can get it to 3 but it is going to be very close at the tunnel.
HHStang, What do you mean about having the rear up at the same 3.5 degrees?
Shakin66
628
Sep 19, 2005
  • Sep 19, 2005
Also the crossmember from Darkhorse does allow for 3 degrees. And the Carb mounting area is not level with the engine so be careful there.
G
gsxrken
206
Sep 19, 2005
  • Sep 19, 2005
You want the slope of the drivetrain to be parallel to the slope of the pinion yoke. So if you are at 3.5* down, the pinion yoke should be a 3.5* up. I've heard that anything more than a 1* difference is a vibration, consumes some HP, and shortens u-joint life.
I guess the darkhorse member for the T-56 is better than their one for a TKO600. That, or the 5.0 block trans flange is much lower than that of a 351W.
H
HHStang
566
Coastal SC
Sep 19, 2005
  • Sep 19, 2005
exactly like gsxrken said. If your tranny is pointed down, your pinion needs to point up. This is all with no suspension load. They offset each other so as your suspension drops, they get close to a zero degree offset. See this link. http://www.carcraft.com/howto/91758/
R
Ronstang
1,294
Houston Texas
Sep 19, 2005
  • Sep 19, 2005
Three degrees relative to the rocker panel is the stock drivetraing angle. 3.5 is not too bad actually but if you can get it to 3 then I would do so if I was you.
Shakin66
628
Sep 20, 2005
#10
  • Sep 20, 2005
  • #10
I can get it to 3 degrees but I want to make certain that the t-56 does not contact the tunnel. I have about an inch all around now and thanks for all the help.
ozstang65
313
Sep 22, 2005
#11
  • Sep 22, 2005
  • #11
Shakin66 said:
...And the Carb mounting area is not level with the engine so be careful there.
Yeah, some aftermarket manifolds are different. The stock setup (at least on mine) is level.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
