Engine tilt question?
I am installing a t 56 6speed and I know one of the problems with doing this is the driveline angle being to great causing the engine to lean back to far. I have cut the tunnel and it is currently at 3.5 degrees. I just cant remember if its 3 or 4 that is best and want to mount the crossmember today if someone out there has the answer that is.
3 degrees is the stock angle. Use your rocker flange to figure out and control for any rake the car may have in its stance. You'll have to make up a crossmember out of tubing and angle iron etc to hold the trans at that angle. None of the commercially available x-members position the tranny correctly b/c they figure you weren't going to do it right and cut the tunnel. Post some pics if you can!
You want the slope of the drivetrain to be parallel to the slope of the pinion yoke. So if you are at 3.5* down, the pinion yoke should be a 3.5* up. I've heard that anything more than a 1* difference is a vibration, consumes some HP, and shortens u-joint life.
I guess the darkhorse member for the T-56 is better than their one for a TKO600. That, or the 5.0 block trans flange is much lower than that of a 351W.
