Engine tuning help please
  • Thread starter Thread starter artbillingsley
  • Start date Start date Apr 16, 2004
A
artbillingsley
10
Lafayette, LA
Apr 16, 2004
  • Apr 16, 2004
I recently did a 6 to V-8 conversion on my 66 mustang. I dropped in a 302, 285hp crate engine from the Engine Factory. My problem is when the engine warms up, approximately 5 or more miles, and I get in to it a little it bogs down like its starving for fuel. It also tends to run a little rougher at idle and sometimes dies when at a stop. No problems at all when cold. I've already replaced the fuel lines with 3/8 alum. tubing and routed it away from any heat sources. The engine is timed at 12 deg BTDC at idle and unvacuumed, increasing to about 38 deg BTCD at 3500 rpm and vacuumed. The engines specifics are 302 ci, roller cam, edelbrock 650 cfm 4 bbl on eldelbrock performer dual plane intake. HEI electronic ignition, high flow GTP Ford iron heads (sometimes called P heads), Stans headers into 3" dual exhaust with H pipe and flowmaster mufflers. It has a C-4 automatic into a 9" ford rearend with 3:50 gears. Any suggestions will be greatly appreciated as I've come to a roadblock as what to try next. I really thought a had a fuel line problem after reading several previous posts on this forum.
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Apr 17, 2004
  • Apr 17, 2004
Sounds like a nice setup, should scream, I had a torque converter in a C4
do just that. When it wormed up it would lock up to fast and stall the motor at idle and have no performance. When I kicked it to the floor the engine would bawg down like a fuel or ignition problem. With that seup you need a 2500 stall. Then the FUN begins.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 17, 2004
  • Apr 17, 2004
Carb too much choke.
D
D.Hearne
11,730
south louisiana
Apr 17, 2004
  • Apr 17, 2004
Choke sticking
A
artbillingsley
10
Lafayette, LA
Apr 17, 2004
  • Apr 17, 2004
I looked at the choke and can see no problem, but is there a better way to check it, I live is South Louisiana and the choke is open even when the engine is cold.
D
D.Hearne
11,730
south louisiana
Apr 18, 2004
  • Apr 18, 2004
Lafayette? I'm just up the road in Opelousas. Just me but, all my Holley carbs have had the choke assemblies removed, you just don't need them here. Even on the coldest mornings, I usually just have to baby the motor a few minutes to get it idling. Otherwise they just fire right up and idle on their own.
67coupestang
509
  • Apr 18, 2004
when its warmed up check for fuel in the bowl...
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • dan50
  • Jul 18, 2026
dan50
