Build Thread Enola- Finishing touches
  • Thread starter Thread starter a91what
  • Start date Start date May 31, 2015
  • Tags Tags
    393 4r70w megasquirt ms3 ms3pro turbo watermeth injection
  • 156
  • 157
  • 158
  • 159
  • 160
  • 239
First Prev 158 of 239 Next Last
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 9, 2018
#3,141
  • Oct 9, 2018
  • #3,141
a91what said:
I did try to put a turn or 2 on the adjuster when i got to work, the cable is tight. tighter than i think it should be.
There is a fair amount of preload on the clutch cable. Tighten it up and as long as 2nd gear upshift gets good rubber, you are OK. That works OK with a Tremec 3350, but maybe not so good with a T5.
OR spare the fragile T5 and try this trick...
If the clutch slips when you put it in 5th gear and floor it, then the cable is too tight
RaggedGT
Mod Dude
Jul 20, 2014
4,752
3,206
203
Taylorsville ky
Oct 9, 2018
#3,142
  • Oct 9, 2018
  • #3,142
a91what said:
you buyin? at this point i would put a stock aod in just so i can drive the car....
Sadly I’ve spent all my transmission funds for the year on an aode.. I know a Hawaiian guy currently parting out some foxes though
General karthief
Mod Dude
Aug 25, 2016
28,030
10,656
213
polk county florida
Oct 9, 2018
#3,143
  • Oct 9, 2018
  • #3,143
And I dumped that trans for 50 bucks, I would have given that to you too.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 9, 2018
#3,144
  • Oct 9, 2018
  • #3,144
Ok today after it was hot I could not get it into 1st... revved engine till it hit the limiter and the clutch pushed in farther... and car went right into gear.....
What's that mean?
Sparky714
5 Year Member
Oct 16, 2015
375
210
73
North Dakota
Oct 9, 2018
#3,145
  • Oct 9, 2018
  • #3,145
Does the transmission still have the aluminum bearing retainer? Throw out bearing may be binding up on the retainer?
Reactions: Noobz347
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 9, 2018
#3,146
  • Oct 9, 2018
  • #3,146
Using steel retainer
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 9, 2018
#3,147
  • Oct 9, 2018
  • #3,147
Something is moving around on the clutch linkage....
Help for those who have replaced the clutch assembly and are still having problems with adjustment:
The next step doesn't make much sense it you already have the transmission installed, but just for sake of discussion, here it is:
The throwout bearing sits in the clutch fork arm with the wave springs pressing on the rear flange of the throwout bearing.
Major differences between the distance between the flywheel surface and the clutch fingers may require tinkering with the clutch fork pivot ball. Stack your old pressure plate, clutch disc and flywheel up like they were when installed in the car. Tighten down all the pressure plate bolts and measure the distance between the clutch fingertips and the flywheel face.
Too much thickness will cause the clutch fork arm to sit too far back to get the clutch cable on the quadrant. It may even sit against the rear or the bell housing hole for the clutch fork arm. In that case, reduce the pivot ball height.
Too little thickness will cause the clutch fork arm to sit too far forward and bottom out against the front side of the bell housing hole for the clutch fork arm.. This will prevent the clutch from fully disengaging.
In other words, the clutch fork arm should sit positioned midway or a little towards the rear in the bell housing hole for the clutch fork arm when the cable is properly tensioned.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Oct 9, 2018
#3,148
  • Oct 9, 2018
  • #3,148
With my truck I have to rev the engine up and on its way back down it'll drop in gear.
General karthief
Mod Dude
Aug 25, 2016
28,030
10,656
213
polk county florida
Oct 9, 2018
#3,149
  • Oct 9, 2018
  • #3,149
Reach under there and try to move the clutch lever up and down, vertically, you may have dislodged it from the ball at the other end.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 9, 2018
#3,150
  • Oct 9, 2018
  • #3,150
Hmm... even with a different clutch in there I remember it being hard to shift but nothing like this....
I may step back and punt, put the car up for a while until I can find a pivot ball, clutch fork and buy a new clutch.... also swap in a trans while I'm at it....
I'm never gonna drive this thing.
Reactions: General karthief
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 10, 2018
#3,151
  • Oct 10, 2018
  • #3,151
Well gents if I am going to do this I need help picking a clutch. I have a zoom replacement in there now and dont have alot of money to burn. I want something that will work correctly and quality. This is getting old fast.
67coupe
658
402
93
Huntsville, AL
Oct 10, 2018
#3,152
  • Oct 10, 2018
  • #3,152
Where does the clutch engage when releasing? Close to the floor, mid way, or toward the top?
Sparky714
5 Year Member
Oct 16, 2015
375
210
73
North Dakota
Oct 10, 2018
#3,153
  • Oct 10, 2018
  • #3,153
I put a Spec stage 2 in mine last winter along with a brand new z spec T5. Broke it in as recommended and it works great. I don't have experience with any other brands though, so just my personal experience. I believe our cars are at similar power levels.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 10, 2018
#3,154
  • Oct 10, 2018
  • #3,154
Clutch feels like it releases at the top of the pedal and engages near the middle. Until the car warms up of course.
90sickfox
Mar 2, 2015
6,946
5,818
213
Oct 10, 2018
#3,155
  • Oct 10, 2018
  • #3,155
With the stock t5 I wouldn't put too hard of a clutch in front of it. An on off switch will be hard on internals. A little slip can go a long way on a weak transmission. Stage 2 is probably the firmest I'd go. Spec is a good brand...I've had good luck with them.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 10, 2018
#3,156
  • Oct 10, 2018
  • #3,156
I picked these.
ARP 150-2202 - ARP High Performance Series Pressure Plate Bolt Kits
Summit Racing SUM-700140 - Summit Racing® Clutch Forks
McLeod Racing 75105 - McLeod StreetPro Clutch Kits
90sickfox
Mar 2, 2015
6,946
5,818
213
Oct 10, 2018
#3,157
  • Oct 10, 2018
  • #3,157
I like their twin disc. I love every car ive installed one in. It's expensive.... but jeeesh it feels good and light on the knee.
CarMichael Angelo
8,909
234
Birmingham, al
Oct 11, 2018
#3,158
  • Oct 11, 2018
  • #3,158
I had the same one in the Red car..the pedal felt like the clutch in a Honda Civic.
Reactions: 90sickfox
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 11, 2018
#3,159
  • Oct 11, 2018
  • #3,159
I like a heavy clutch myself....
67coupe
658
402
93
Huntsville, AL
Oct 12, 2018
#3,160
  • Oct 12, 2018
  • #3,160
Had a clutch that wouldn’t keep its adjustment. Keep acting like that cable was getting longer (release point kept moving toward floor). Turns out the pivot ball was loose and backing out of the bell housing. Probably not your issue, but I’d take a look since you’re pulling it apart.
  • 156
  • 157
  • 158
  • 159
  • 160
  • 239
T
TJ's Eaton M90 Build-Up Thread
  • tjh566
  • Jan 8, 2007
  • 1994 - 1995 Specific Tech
  • 3 4 5
30K
1994 - 1995 Specific Tech Oct 15, 2007
RAD
R
