Buy a set of BBK unequals, 1 set of Mr. Gasket ultra seal exhaust gaskets, and 1 set of stage 8 locking header bolts. You will be set, and you won't even miss the 3 extra horsepower! I had a set of Mac equal lengths and they were a major pain to install. Not really because of their size except for the fact that they hit on my steering shaft and I had to take them back out and ding them to fit. You can imagine all the different directions those single flanges went by the time I got done dinging the headers down by the collectors. I had to do all kinds of jacking, and squeezing, and prying, just to get all the bolts to go in. One other thing I know that could really help a lot of people is that on the mac's and the bbk's the flange on the bottom by the collector is only skip welded in about four places. These welds will crack as you try to tighten the mid-pipe up to them, and then the flange will bend down as you tighten the nuts on the studs and keep you from getting a real good seal. I took mine into work and had the flange welded solid all the way around the collector on the bottom side of the flange. No more cracking! Oh yeah get the stage 8 locking bolts from Summit or elsewhere with the Ford racing part #! They are 1" long bolts and they are the perfect length. 3/4" is too short.
