1. I believe this is a solonoid that is connected to the gas tank? Where is the exact location of this solonoid?
2. If this is true could it mean that this solonoid is bad and needs to be replaced?
3. Can this solonoid be removed and bench tested?
4.Or could there be a different solution to the problem?
I just bought the car. Its a 2000 with 2003 cobra trim. Gas tank replace back car getting painted. Transmission blew on way home. Back half caught on fire Idle'n. Just replaced tank everything is hooked back up! Any one have suggestion? Also need new filler with all plastic stuff that goes with. Thank You in advanced.
Nate--
Nate--
