  • 2005 - 2009 Specific Tech
ETC Button
  • Thread starter Thread starter 07gtcs
  • Start date Start date Dec 18, 2006
1 of 2 Next Last
07gtcs
31
  • Dec 18, 2006
I can't tell the difference between ETC on or off. Does the button on the dash really turn off ETC, or is there another way. Living in Florida, I don't foresee needing ETC.
Spdfreak
276
  • Dec 18, 2006
Peel out with it off AND on. You'll see the diference.
Schlitz-420
97
Michigan
Dec 18, 2006
  • Dec 18, 2006
You can shut off this feature permanently with almost any programmer. You will not notice it being on or off unless and until you give enough power to break the tires loose. I can't wait to shut mine off as i sometimes forget it's on and stomp on it only to look like a fool when the gas is cut because i started to break one loose.
07gtcs
31
  • Dec 18, 2006
It's probably harder for me to tell because my car is an Automatic and it has 18" wheels and a huge footprint...it feels the same way both on or off. I'm going to have to supercharge it, to be able to peel out like a Mustang was born to do.
Schlitz-420
97
Michigan
Dec 18, 2006
  • Dec 18, 2006
So are you saying you can light the tires just as well with it on as you can with it off? If so it is not working and i am jealous.
07gtcs
31
  • Dec 18, 2006
No, I can only get a chirp from a full stop to full throttle with the button in either position.
I have a 66 fastback with a stock 289 and a stock 2bb carb that will light the tires in first and also catch second, and it is also auto. Now, the footprint on the 66 is tiny compared to the huge footprint of the 07.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 18, 2006
  • Dec 18, 2006
the first problem is that you have the stock tune, correct? if so, then that is the biggest hinderance to your burn out capabilities. the throttle does not respond well under 2500 RPM, especially with an auto. if you get a tuner and flash the PCM, you will have better luck.
07gtcs
31
  • Dec 18, 2006
You are correct, stock tune. I hope my wife gets me a cold air intake and a tuner for x-mas
I've been a good boy this year
Emay
228
South Elgin, IL
Dec 18, 2006
  • Dec 18, 2006
You try brake torqing the car at all to see the difference? That's the easiest way to see the difference given your off the line lack of spin currently. If you brake torque it and it starts to cut power, then you know it's working. Or wait for some rain and try it then..
07gtcs
31
#10
  • Dec 18, 2006
  • #10
Emay said:
You try brake torqing the car at all to see the difference? That's the easiest way to see the difference given your of the line lack of spin currently. If you brake torque it and it starts to cut power, then you know it's working. Or wait for some rain and try it then..
I'll try that, thanks.
Mr_Q
721
Burbank, CA
Dec 18, 2006
#11
  • Dec 18, 2006
  • #11
Brake torque, you'll peel out just fine with the stock tune!
Hell the new auto tranny is a lot more stout and takes it's beatings more so than the current 5spd. Not sure what's going on with that.
xbone
29
#12
  • Dec 18, 2006
  • #12
I have a brenspeed sct tuner, can you permanently shut off the traction control with this thing? How?
bigcat
May 1, 2005
3,015
7200 feet
Dec 18, 2006
#13
  • Dec 18, 2006
  • #13
i believe brent has to turn it off for you. call him and ask about turning off the TCS.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Dec 18, 2006
#14
  • Dec 18, 2006
  • #14
I have the auto(3.55 gears) and 18's and from a standing start I can get my tires to chirp a few times without revving it up while holding the brake. Here is a vid clip of my 0-100 run with TCS on and OD on.
kooldawg6
Aug 31, 2006
1,679
Central VA
Dec 18, 2006
#15
  • Dec 18, 2006
  • #15
I noticed on my run it shutterd big time on the start...like she wants to go, but Ford is holding her back...I will be getting the WMS CAI and SCT2 soon to take care of that!!!!!
JTGrant
775
GA
Dec 20, 2006
#16
  • Dec 20, 2006
  • #16
Yeah the tuner makes a huge difference in how the car reacts. I would go with brenspeed or bamachips.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 20, 2006
#17
  • Dec 20, 2006
  • #17
my friend is making a part so it will default to "OFF" when the car is first started, so you will not have to turn it off completely or will manully have to turn it on.I should be testing one pretty soon.
W
Warlok
89
#18
  • Dec 20, 2006
  • #18
For sure!
The first time I ran my car, at the drags, I thought that leaving the ETC on would help me launch. Between the anti-lock brakes pulsing and the huge drop in power it was ugly!
07gtcs
31
#19
  • Dec 21, 2006
  • #19
Let me know. Is it a mechanical or electrical component?
iskwezm
4,159
20
79
Dec 21, 2006
#20
  • Dec 21, 2006
  • #20
electrical, just a basic plug that can be removed for "dealer work"
1 of 2 Next Last
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
