ethanol
  • Thread starter Thread starter jghood13
  • Start date Start date Apr 25, 2006
J
jghood13
160
NY
Apr 25, 2006
  • Apr 25, 2006
If ethanol replaces gasoline will we be able to adapt our cars both carbureted and fuel injected to work?
Modular2v
3,222
23
99
oklahoma
Apr 25, 2006
  • Apr 25, 2006
as long as it combusts...i dont see the problem except maybe some tuning issues such a spark plugs....DONT GET YOUR HOPES UP on ANY alternative fuel source though
87'GTstang
1,025
  • Apr 26, 2006
The main problem with ethanol, and the reason you won't see it in 100% form (and the failure of it for the past decades) is that it isn't efficent. It takes an engine to run more rich a/f mixtures (lower octane ratings being the problem) therefore it consumes more of it. Just find some old field tests of the ranger/taurus from the 1996 experiment and try to dig up the results. Also if they went to pure form, special fuel systems are needed with a lot of expensive stainless steel fuel system parts.
The technology has been around for a long time, it's sister alternative (methanol) didn't work out so well so all you see at most is E85 for vehicles capable of using it, even that is only 85% of it.
If you think about it, if they squeeze 5%-10% of it into every tankful, and lets say we used 1 mil gallons of it a day, that's 50,000-100,000 gallons less that we buy from those greedy bastards at OPEC.
squeeeg
1,905
Michigan
Apr 26, 2006
  • Apr 26, 2006
Has anybody tried to use E85 in their 5.0? Any success in tuning it and getting it to run right?
LilRedPony
31
Arizona
Apr 26, 2006
  • Apr 26, 2006
Turbomustangs.com ran a test with a twin turbo setup on E85 and made 1000+ RWHP. http://www.turbomustangs.com/techarticles/e85dyno.php
Ethanol has a very high octane content and that makes it ideal for super/turbocharged or high compression engines. E85 has an octane content of 104-108 or so, compared to super-unleaded at 93 its basicly race fuel. It is less efficent than gasoline so more of it has to be used to maintain a good A/F ratio, with E85 it is said you will see about a 10-15% drop in MPG. Both Ford and GM have produced a number of FFV's (Flex Fuel Vehicles) that can run on both gasoline and E85 or any mixture of the two, they have a sensor that detects the ethanol content and adjust the A/F ratio.
Mikey1968
232
Kommiefornia
Apr 26, 2006
  • Apr 26, 2006
I'm pretty sure that ethonal will dry out your rubber seals and hoses. Bad on carbs but I think the fi system uses a different compound in the seals that can handle it. Not sure, though.
mattmcdan
176
Okeechobee, Florida
Apr 26, 2006
  • Apr 26, 2006
I read somewhere a long time ago, that ethanol starts to seperate when it sits, like the water seperates from the fuel, you need a fuel sperator to run it in street cars along with stainless components. (not sure where I saw that)
Fuel Damper, 2003 Mustang GT
  • bmmckl
  • Dec 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 19, 2025
bmmckl
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
