evap system removed by previous owner
  • Thread starter Thread starter rockyracoon
  • Start date Start date Dec 28, 2011
R
rockyracoon
874
27
49
margate NJ
Dec 28, 2011
  • Dec 28, 2011
Hey guys,
The previous owner saw fit to remove the cannister and the lines so my question is if I wanted to restore the evap what exactly wouldI need. is it just the cannister,purge valve, and the lines ?
Can someone tell me how to route the lines. So does the cannister have 2 lines going to it ? one from the tank and then the other one going to the intake with the purge valve in between. where on the tank does the line connect ?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2011
  • Dec 29, 2011
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
The purge valve solenoid should be available at your local auto parts store.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
foxbodymike87
739
35
39
Dec 30, 2011
  • Dec 30, 2011
the lines run down the passenger side of the car
stang&2Birds
2,091
New England. :-) CT/MA
Apr 16, 2012
  • Apr 16, 2012
jrichker: You rock!
The purge valve solenoid just went on my car. I did a search, and found your awesome info.
Thanks!
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
  • Locked
2001 evap core tube support
  • mnky99
  • Sep 4, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
