  • SN95 4.6L Mustang Tech
ever cracked a bolt???
  • Thread starter Thread starter seany425
  • Start date Start date Apr 4, 2005
seany425
90
  • Apr 4, 2005
i have an 02 gt, gonna be puttin headers on in the next few weeks, now my car is only a few years old so im not toooo concerned about this but has anyone ever cracked a bolt inside their block during a header install???? i just dont want this to happen and, then be SOL should i be worried???
nickthegenius
1,631
Elwood, IN
Apr 4, 2005
  • Apr 4, 2005
Its typically recommended to reuse the factory studs and nuts on the 4.6L. If you reuse the studs, you're not going to be removing them anyways. When reusing the studs, it also makes it much easier to hang the new headers in place during the install. That's definitely a plus if you're working alone. Also, don't go cheap on gaskets. Either get new OEM gaskets from Ford or a set of Percy's layered aluminum gaskets. Otherwise, you will be un-installing your headers sooner than you would like.
I've broken a stud off in a head before, but it was on a Plymouth 318. I had to have a guy bring over a right-angle drill and drill and retap the hole. It never was quite right, though.
04silvergt
28
  • Apr 5, 2005
dont worry take your time and soak them with a penatrating oil and they will come of with ease
Jones331
Banned
Oct 2, 2004
142
Oakland CA
Apr 5, 2005
  • Apr 5, 2005
Yea my dumb a** cracked one of the bolts that holds the stock plenum down to the lower manifold.It cracked half hay down the plenums bolt hole so there was NO getting to it So I unbolted the rest of the bolts and spun the plenum around untill it came off ............jj
upon re-reading youre post and NOT just the title I realized my responce had absolutly nothing to do with youre question! Damn I new not eating all day untill 8 p.m affected me somehow..........
T
tarch
My 8V > 4V > 2V
3,073
Redmond, WA
Apr 5, 2005
  • Apr 5, 2005
i cracked a nut on the exhaust manifold at the track once... that was very fun
seany425
90
  • Apr 5, 2005
what did you do, and if i take my time you think ill be fine??? or is it just bad luck if it happens it happens?
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
