Ever had this cooling issue?
  • Thread starter Thread starter Noobz347
  • Start date Start date Feb 8, 2011
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
  • Feb 8, 2011
So there I was....
I put a monster 2 row aluminum radiator in the car a year ago or so. I'm using a 180* t-stat. It's one that has the small hole in it that allows pressure equalization between the engine and the cooling system so that the t-stat is never held in in either the open or closed position due to pressure from either engine RPM or exapansion or whatever.
Here's the problem though... It's winter time and I often don't see operating temps indicated on the temp gauge unless I'm sitting at idle. Just as soon as I get moving again, I can watch the temp gauge fall.
So my question... How much water/coolant is actually allowed from the engine to the radiator via the coolant by-pass hose? Has anyone ever restricted flow through this hose? Is it effective or worth doing?
What are some other potential solutions aside from blocking off the radiator? (i've tried this, it's inneffective at best). I guess I'm looking for more of a permanent solution or maybe there's something I should have done when installing this larger radiator that I didn't do.
The radiator is definitely overkill for this time of season but not for when it's warmer (well maybe a little but no drastically). I'd prefer to have a little more cooling capacity than needed vs. not enough.
Suggestions?
M
mwood
177
  • Feb 8, 2011
You ever see trucks running around with cardboard ziptied to their radiator in the winter?
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
  • Feb 8, 2011
Yep... and I've done this as well. I've even gone as far as making up a piece of aluminum with slots cut in it with attaching hardware.
It seems to me though, that if coolant flow is application matched, that this kind of thing might be unnessesary?
M
mwood
177
  • Feb 8, 2011
The coolant flow design of the 5.0 motor was based on the stock radiator. Two outputs from the waterpump. One bypasses the thermostat to give you heat. You upgraded the radiator. So it is no longer matched.
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
  • Feb 8, 2011
It wasn't matched before either. It was inadequate when the motor was supercharged, bored, and stroked.
That's kinda the point of the discussion. I want to try and bring it back into balance without resorting to band-aids.
M
mwood
177
  • Feb 8, 2011
One question. What fan do you have? Electric or OEM? An electric fan is also therostat controled. Will not run when too cold. Might help.
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
  • Feb 8, 2011
I have the OEM style clutch fan (also thermostatically controlled).
I've definitely considered an electric fan but I'm not so sure that, that would cure my current problem. When I'm moving, I loose a lot of heat in the coolant.
What's your thought process on the fan?
M
mwood
177
  • Feb 8, 2011
Your problem is the radiator plus current coolant flow design. Coolant keeps flowing around the themostat via the heater hose to the firewall. The electric fan places a thermostat in the radiator fins. My electric fan doesn't even run most of the time in the summer. Shouldn't run at all in the winter. Not sure if the OEM fan is running or not. Either way the electric fan might not help. Easiest solution is covering up the radiator in the winter.
M
mwood
177
  • Feb 8, 2011
Really dumb question. What temp is it running at what temp outside? It was 10 below here this morning. If it takes that to pull the temp down on your stang and is still running 140, why loose sleep?
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
#10
  • Feb 8, 2011
  • #10
The OEM fan DOES move when the engine runs, true. When it gets hot the clutch holds it tight and it turns at engine speed.
I have the restrictor in-line with heater core. I was considering running an additional restrictor in the coolant by-pass line as well. Coolant would still flow but not as fast. I wonder though, if restricting flow in that by-pass line might cause excess pressure though. I mean... that's what the by-pass line is for, isn't it?
I see your point about the electric fans though. Yes... the OEM fan does rotate whether the clutch is engaged or not. The negative pressure behind the radiator might be reduced a little by using an electric fan that doesn't rotate at all (with exception of being pushed by air). Might be worth just pulling the fan off for a day and see how much of a difference it makes in cooling while moving. My suspicion though, is that it's probably not much. Worth a shot and doesn't cost money to try though.
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
#11
  • Feb 8, 2011
  • #11
Ah... I might also that I'm running an inducted cowl. I'm sure that also helps to create negative pressure behind the radiator. Great when it's hot out... maybe not so great when it cold and cuasing even more flow through the radiator.
In the end you may be right. I may not be able to have it both ways.
M
mwood
177
#12
  • Feb 8, 2011
  • #12
One more thought for you. Not sure what waterpump you are running, but you might benefit from underdrive pullies. Or at least an underdrive for just the water pump. The issue is whatever you do to help the winter hurts you in the summer. That's why a radiator cover is easy. Can be removed in the summer.
Admin Dude
Jan 4, 1985
43,577
21,741
234
Box behind Walmart
Feb 8, 2011
#13
  • Feb 8, 2011
  • #13
That would be a quick fix.... Hmmmm.... might be worth a shot and if I get elevated temps during summer, I can swap it back.
I missed your Q above till just now. I don't know the specific temps that I'm running at. I use the stock temp gauge so my normal operating tempurature is, "O" and goes down to the, "C" when running in cool climates. lol Outside temp this morning was 28*. I get almost no temp indication other than heat coming from my vents, that I'm getting any heat soak at all.
The largest concern I suppose, is that even though I run synthetic oil, I want to ensure that it's getting that oil to operating temp to rid itself of the water that oil pulls from ambient air.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Feb 8, 2011
#14
  • Feb 8, 2011
  • #14
I fought this problem on my vert the whole time I owned it. Couldnt get heat in the winter and it ran low temps in winter. I had a 4 inch cowl hood with the vents opened on back of cowl....that may well have been hurting it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Feb 8, 2011
#15
  • Feb 8, 2011
  • #15
The problem is you are using the stock temp gauge to judge. They are notoriously innaccurate. You really have no idea where the temp is siting. It could fall off the gaug but in reality be around 180 degree. You have no idea.
Secondly. 180 t stats aren't really ideal. The colder t stat trick is a holdover from the carved days. With efi, you really want to be a bit warmer...especially if your cooling system is as efficient as it seems.
But without a gOod gauge on it, we have no idea what kind of temP swings you are seeing.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Feb 8, 2011
#16
  • Feb 8, 2011
  • #16
Carbed...not carved.
Damn iPhone
1991notchbackLX
1,483
47
48
New York
Feb 8, 2011
#17
  • Feb 8, 2011
  • #17
I agree with Mike, as usual. Combustion engines have what is known as an optimal running temperature for efficient operation. There's a reason Ford engineered a 195* thermostat into the 5.0L engine. Lubricating oil has different properties at different temperatures. Wear on lubricated parts within the engine can increase significantly when the temperature of the oil is decreased. Reinstall the stock 195* thermostat and call it done.
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
P
Mishimoto Radiator leak 1987 Foxbody 5.0
  • PHoffman
  • Jan 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 18, 2025
Trogdor
