Exceptionally Clean 1984 Bronco Wny $5500 Obo
electricgreen
1,140
Western NY
Exceptional Arizona truck! 351, automatic, dual front shocks, cruise (works!), rear window works from both the switch and key. Shows 81k on the odometer and we believe that is the actual mileage. Had AC, previous owner took it out but have the parts. You won't find another like this one! Recent repaint because the clear coat was peeling, we do have a few photos before to show it wasn't to hid rust. We didn't plan to sell it, just bought a new house and don't have as much driveway space as we used to and we have to give up something. Needs a muffler, one trim piece on the front fender and some interior work (dash pad was cracked and has a cover on it from the sun, some rips in the seat that could be covered with a seat cover). There is a little surface rust on the floor from wet feet and having the top off. The rubber flooring was shot (again, AZ heat and sun) so we removed it-you can see the floor pans and see how nice this truck really is. If you like classic Fords, don't miss this one. Broncos are getting harder to find, and it's even harder to find a rust free one! Also, this does have a trailer brake controller, it was disconnected by the previous owner but appears to still be intact (we've never used it). It looks like it was ordered this way from the factory (set up for towing)-it also has a class 3 hitch. We have never driven this in the winter, but did try using the 4wd and it does appear to work. It has locking hubs and a shifter, not a push button 4 wheel drive like newer model trucks.
driver's side floor pan/frame:
