  • 1994 - 1995 Specific Tech
Exhaust advice
  • Thread starter Thread starter sage2k
  • Start date Start date Sep 30, 2005
sage2k
645
Baton Rouge, LA
Sep 30, 2005
  • Sep 30, 2005
I am going to get an h pipe and install it in a month or so
and later Iwant to get some decent mufflers. Im not asking for brand advice, ill figure that out. Now waht I have seen is that catback kits are so expensive
Should i save for a catback or should I just buy the mufflers seperate? Or can I even do that?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 30, 2005
  • Sep 30, 2005
Spend the money and get a decent cat back. I know they are rediculously expensive, but they are worth it in the end. The cheaper kits rust, etc.....
But you should definately do it all at once. See if you can get access to a lift and you will get it out in no time.
Just don't get the summit h-pipe.......
Scott
95COBRA241
339
Delray Beach, FL
Sep 30, 2005
  • Sep 30, 2005
You could just buy the mufflers, but most likely your exhaust is 2.25". Therefore the only improvement will be sound. Save for a good 2.5" cat-back.
a50sn95
368
Elk Grove, CA
Sep 30, 2005
  • Sep 30, 2005
Find someone that has one and SOUNDS like what you want yours to sound like. Then get that one. Nothing more disappointing then getting something and not liking how it sounds after. (I sold my magnapack kit because it was just too obnoxious. Yes, I'm old...)
A
AdamFogle
38
Frederick, MD
Sep 30, 2005
  • Sep 30, 2005
Do Both
Def. do both at the same time. I just got my catback (flowmaster American Thunder) for 320 from summit. Thats with stainless pipes. I could have gotten regular for 240. The mufflers themselves are like 70-80 a piece, and then you have to weld them in. Also, your h-pipe will be 2.5, so it would be better to have your exhaust the same size instead of the stock 2.25.
ARMAGEDON
100
Sep 30, 2005
  • Sep 30, 2005
Get the 2.5" Cat Back. Flowmaster American Thunder for the rumble, or three chamber for a bit quieter rumble. Throw in 2.5" electronic dumps in between the hpipe and cat back for a whole lota fun.
Zero Signal
2,633
Tucson, AZ
Sep 30, 2005
  • Sep 30, 2005
I would do an H-pipe before doing the cat-back after seeing the differences first hand. The stock exhuast with no H-pipe sounds pretty decent.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
L
Is catback worth it over axle backs?
  • Lorencarson
  • May 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 15, 2025
89ripper
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
