Exhaust bolts question
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,487
2,909
173
Florida
Are these exhaust hanger bolts in the attached pic self tapping or do I need to run a tap through the hole I drilled in the frame for my dual exhaust hanger???
Thanks
They are self tapping. If the bolt is 5/16" then the hole it is "self tapping" into should be around 1/4" maybe a tiny bit less.
The above is an example.
A 1/4" self tapping screw/bolt should have a pilot hole of 3/16" or slightly less.
So on and so forth.
Reactions: limp
