  • 1994 - 1995 Specific Tech
Exhaust clearance
  • Thread starter Thread starter 94Blue302GT
  • Start date Start date Jan 24, 2006
94Blue302GT
704
Chicago
Jan 24, 2006
  • Jan 24, 2006
I have a turbo and i'm running my exhaust downpipe etc. and I can get it down below the vehicle (finally) without hitting anything, but now i'm wondering about ground clearance with my muffler. I'm using 3" pipe and tucking the cat. converter right under the hump in the trans. brace where the stock exhaust ran, so it can sit up in the car a little higher. The problem i have now is I've bought everything to kick the the exhaust out the side (this is all on pass. side btw) but don't know if i have enough ground clearance to put it anywhere.
What do you think the min. ground clearance should be for a road car?
P.S. I have another pipe setup for a straight through for going to the track, but for the street i need to have the cat and muffler for emissions and noise police.
donjohn
1,757
Irvine - Southern California
Jan 24, 2006
  • Jan 24, 2006
probably depends on what springs/suspention you're running and if you still have the pinion snubbers on there... and then there's speed bumps
don't vettes run like 4" off the ground?
anyways, free bump
94-302-vert
1,947
NE CT
Jan 25, 2006
  • Jan 25, 2006
I would say 4" or so minimum... my K-brace is about 3" off the ground and I hit it on the road sometimes (jsut from road undulations)...
94Blue302GT
704
Chicago
Jan 28, 2006
  • Jan 28, 2006
well, i'm thinking that Indiana may not require you to have a muffler, so i'm thinking i'll run it just with the cat and see what they say.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
