exhaust leak help please!!!
beaver2489
503
st. joseph missouri
I got my 306 running today, but I got a bad leak on the passanger side header to x pipe collector. No matter how I position the x pipe before I tighten the collector bolts I still have a bad leak. I can feel the exhaust blow out quite a bit. Is there a sealant for this? Like the red silicone **** you use on rearends, but high temp sealant? Thanks
You can try loosening the bolts, jacking up the xpipe EVENLY up till there is a fair amount of tension on the whole thing, and then tighten up the bolts. It helped a lot on my friends recent MAC equal length header install. (I personally will never get a MAC header, fit and finish was not the best)
i have a similar problem and i plan on going down to checker and geting a 2 1/2 exhaust gasket, it isnt made for our cars but ill just sandwich it in between them and i have a feeling it will work. i have heard other people on here doing that.
