  • 1994 - 1995 Specific Tech
exhaust problems
  • Thread starter Thread starter White94GT
  • Start date Start date May 31, 2004
White94GT
59
St. Louis, MO
May 31, 2004
  • May 31, 2004
I have the MAC 2.5 inch cat back system on my car and i just got some 17x9 cobra r's, and they won't fit because the tire rubs on the exhaust pipe. Has anyone else had this problem? Will I need to go with a side exhaust or is the cat back system just mounted on the car wrong?
Joes95GT
3,132
Delaware
May 31, 2004
  • May 31, 2004
It is fairly common and can be fixed by an exhaust shop for 30 bucks and about 15 minutes worth of work. Chances are that something isn't installed correctly, but in some cases, the exhaust does need to be cut and modified.
Joe
1hot5.0
1,615
Surprise, Arizona
May 31, 2004
  • May 31, 2004
My friend had this problem on his 89 gt with the same rims. He ran 275's in the back, and had a Flowmaster 2.5" catback. We took off the Tailpipe and muffler (on that side), reinstalled it, and he never again had a problem.
jmuva44
1,338
Richmond, VA
May 31, 2004
  • May 31, 2004
I had my exhaust hitting the frame but never the wheels. It just needs to be loosened and twisted to work.
VIPERn94Five-0
3,352
Poughkeepsie, NY
May 31, 2004
  • May 31, 2004
i do love my Bassani's fitment...im running 275 tires on my 10.5" wide rims on the back and there is ZERO rubbing on the tires....ive had the passenger side tailpipe wiggle loose and knock on the frame a little bit, but that was nothing a wrench couldnt fix....
....but about your problem....it could probably be fixed by removing the tailpipes and positioning them better...but if not any exhaust shop worth a darn could fix it easily...
Anthony
White94GT
59
St. Louis, MO
May 31, 2004
  • May 31, 2004
thanks for the help, i already fixed it, it only took like 10 minutes.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
