Exhaust
DeGTroitMuscle
11
So im looking at doing my exhaust, and starting with a mid pipe, i found a video of an off road mid pipe and stock everything else. my question is, when starting the exhaust process should i start with the mid pipe, then headers, then mufflers? Or I was thinking mufflers, headers/midpipe. Im not going to do it all at once, so let me know what you guys have had good luck with, and what you think the best order to do things is
Are headers really that much of a bitch to put on s197s or does it go fairly smoothly if I were to do it myself. I have a lot of experience with cars but I've never taken a block off the mounts and for 600 bones to install it, I'd be willing to give it a shot
arent there issues with the O2 sensors when you do LTs though?
Generally, the biggest problem is lengthening the harnesses to reach. If you still run pre and after-cat sensors then you shouldn't have any problems. If you eliminate the cats then you'll need to install MIL eliminators in place of the after-cat sensors.
