expected gains with 6psi
That's it for HP?
I was considering a 6psi kit but i think i can almost make those numbers N/A.
I think some GT-40P cars are putting out more than 300HP at the flywheel.
Here's another question, who is running a 6psi kit (vortech for example since that's what i wanted) with supporting mods such as heads, cam, intake,. TB, etc...and what HP are you putting out? What;s the best you can expect from a 6psi kit?
a 6 psi kit?
I was brainstorming a basic 5.0 setup around a 6psi Vortech kit. The kits can be had for under $2K. I was just wondering what i could expect with all the basic bolt-ons, GT-40P heads a custom grind cam and Cobra intake?
Is 350-400HP to the wheels possible with a 6psi kit?? (not necessarily with the above mods)
This topic came up ohhh, about 4 yrs ago but the thread is gone since the crash of '05. Anyway, some of those guys were making over 300rwhp with stock motors.
I specifically remember one guy that was detailed with every mod and the resulting rwhp. First he added a sc vortech (about $1700 from superchargers for less) and he made 25xrwhp at 5 psi. He then added headers/catback and boost was at 6psi and he made ~27xrwhp. Then he added a 65mm TB and upped the boost to about 8psi (I think this cuts the warranty down) and he made 29xrwhp.
Some of the other people with power pipes and full bolt-ons were up to 340-350+rwhp with the intro s/c kits. This is good power considering they were using stock motors.
so wait if i were to purchase some gt40 heads.with my cobra intakes,tb,xhaust etc. i would be just as close to 300hp as with a 6psi s/charger w/ stock heads.. I dont want to do both i htink thats to much stress for a stock 5.0.....
Do both, you will be just fine if its tuned nicely. Should make 350 or so rwhp, plenty to cook some tires.
Makdaddymac said:
which heads are better gt40 or gt40p i think the gt40p give clearance problems dont they?
The only clearance problem are with the spark plugs, what headers do you have? Just figure that if you buy a used set, you may be in for a $200-$300 valve and freshen up job, so youll end up spending more.
(Here's another question, who is running a 6psi kit (vortech for example since that's what i wanted) with supporting mods such as heads, cam, intake,. TB, etc...and what HP are you putting out? What;s the best you can expect from a 6psi kit?)
Numbers are in my sig. I had to pully back up to 5psi and still use factory computer, no ignition box or timing retard. Base timing is at 10 and plugs gapped at .035" I beleive my catts at the time of dyno were partially plugged as I replaced mid pip shortly after that due to converters. On a stock short block with just the A-trim and full exhaust, larger mass air meter my car made 272rwhp and 318rwtq
Good numbers. Was that clogged cats on a stock h-pipe? With the H/C/I you have, can you get more psi out of the a-trim?
BTW, I saw the Novi 1000 new on ebay for $1600. I bet superchargers4less has them even cheaper.
