Do both, you will be just fine if its tuned nicely. Should make 350 or so rwhp, plenty to cook some tires.Makdaddymac said:so wait if i were to purchase some gt40 heads.with my cobra intakes,tb,xhaust etc. i would be just as close to 300hp as with a 6psi s/charger w/ stock heads.. I dont want to do both i htink thats to much stress for a stock 5.0.....
The only clearance problem are with the spark plugs, what headers do you have? Just figure that if you buy a used set, you may be in for a $200-$300 valve and freshen up job, so youll end up spending more.Makdaddymac said:which heads are better gt40 or gt40p i think the gt40p give clearance problems dont they?
Good numbers. Was that clogged cats on a stock h-pipe? With the H/C/I you have, can you get more psi out of the a-trim?frcefedlx said:Numbers are in my sig. I had to pully back up to 5psi and still use factory computer, no ignition box or timing retard. Base timing is at 10 and plugs gapped at .035" I beleive my catts at the time of dyno were partially plugged as I replaced mid pip shortly after that due to converters. On a stock short block with just the A-trim and full exhaust, larger mass air meter my car made 272rwhp and 318rwtq
