Explorer Engine
  • Thread starter Thread starter fox-gt
  • Start date Start date Apr 30, 2006
fox-gt
204
TN
Apr 30, 2006
  • Apr 30, 2006
Is an 97/ 98 explorer engine a good replacement engine for my dying 5.0? If so, is there anything that has to be swapped or will not work. Are the motor mounts in the same place? Can I use the same computer? Am I better off looking for a 5.0 out of a mustang?
JBeezy53
559
Sacramento, Ca
Apr 30, 2006
  • Apr 30, 2006
The long block and intake is an upgrade over your stock stuff but you will have to use the accessories and oil pan you already have. I would change the cam before you drop it in.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Apr 30, 2006
  • Apr 30, 2006
You will have to use the distributer from your current engine also because the explorer engine has a DIS ignition.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Apr 30, 2006
  • Apr 30, 2006
Just put one in a 90GT for a guy. Pretty much swap balancer, oil pan, pick up tube, timing chain cover, water pump, and add mustang distributor. The explorer cam will work, but should swap out for a better cam. Also depending on which heads you get,(GT-40's or the GT-40P's) different headers might be needed. The intake is basically a cobra intake, and can be used with a little mods. Nothing major, plugging a few holes, swapping the elbow for a mustang throttle body and spacer, and cutting the front vacuum pipe for the charcoal canister.
bubba-dough
1,044
Indiana
Apr 30, 2006
  • Apr 30, 2006
To answer the main question.....yes, it is a good replacement. If you are not wanting a modified motor go with the Explorer and you will get a few more horses over a stock 5.0 out of a Mustang.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 1, 2006
  • May 1, 2006
rebuild the shortblock replacing the cam with an aftermarket piece.
get the heads worked and fab the use the intake, just come vac line mods and it will work great. can also fab the explorer 65mm stock TB to work.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
May 1, 2006
  • May 1, 2006
The explorer TB can be made to work. Have to modify where the throttle cable attaches. What I did was take a stock TB shaft and modified it so the 65mm butterfly fit and swapped it place of the explorer shaft.
fox-gt
204
TN
May 1, 2006
  • May 1, 2006
Is this basically what I would need? I would like to do as much to the engine as possible then do a direct swap only replacing the distributor and headers.
  • 98 Explorer 5.0L Engine 75k miles
  • Used 5.0 mustang oil pan off ebay
  • New oil pump / oil pan gasket
  • New balancer
  • New pickup tube
  • New throttle body / use my current one
  • New exhaust gaskets
  • New water pump / gasket
  • Used Timing chain cover off ebay.
I thought about replacing the head gaskets also since the engine was out of the car also
millhouse
1,985
Simpsonville, SC
May 1, 2006
  • May 1, 2006
  • New balancer
  • New pickup tube
The explorer pump is the same as the 5.0 pump. The pickup is the only difference...and they are re-usable. I suppose though it's cheap insurance to just replace it anyways. Same goes with the waterpump.
I'm not sure what reason you would have to replace the oil pan or timing chain cover.
The exporer timing chain is a single roller unit. I assume it's not nearly as strong as the double rollers found on the mustangs. If you swap cam's I'd go ahead and replace it with a better unit. You can pick up a cloyes true roller for a bit over $40 on summit.
If your using a 98, the sparkpugs are goin to be a Bitch! You'll have problems tightening a couple of plugs I believe on the drivers side. A plug socket wont fit with the stock 5.0 headers, so many chop up their plug sockets to fit. Also keep in mind you'll have issues with the stock plug wire boots touching the headers. You can get away temporarily by swapping the 90* boot end which goes to the distributer...but ultimatly they will still end up melting.
That's about all I can think of off the top of my head. Good luck.
fox-gt
204
TN
May 1, 2006
#10
  • May 1, 2006
  • #10
I have BBK 1 5/8" unequal headers, they have been a nightmare on my current engine, so it might be worse. I figured I would just replace the oil pump and water pump since they are cheap. Is another year better than the 98?
millhouse
1,985
Simpsonville, SC
May 1, 2006
#11
  • May 1, 2006
  • #11
Technically speaking...the gt40p's flow marginally better than the gt40's, albeit small. I'm unsure if the bbk's will help with plug clearance or not. You may want to do a search on the topic as a thread seems to pop up atleast once a week on the subject.
If you dont want to mess with the "p" heads, look for mid-late 96 and earlier explorers/mountaineer's. They will have the gt-40 heads with the standard plug angles. Beware though there are some late 96 explorer/mountaineer's which came with gt40p's.
VG30DE
364
Dudley, MA
May 3, 2006
#12
  • May 3, 2006
  • #12
The actual production dates are 7/95 to 12/96 on the regular GT40 heads... anything newer is going to be a P motor....
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
