explorer heads on 84 mustang
  • Thread starter Thread starter black 96 gt
  • Start date Start date Aug 4, 2009
black 96 gt
35
solon, ohio
Aug 4, 2009
  • Aug 4, 2009
I have a 1984 mustang gt with a carbureted 5.0. I would just like to know, am i going to have any problems putting the gt40 heads of an explorer on a 302 without fuel injection? If it is possible what all would i need?
dcurtis
688
Aug 4, 2009
  • Aug 4, 2009
The heads should be a direct swap, head gaskets and intake gaskets.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 4, 2009
  • Aug 4, 2009
Depending on if they're the GT40P heads, you might need either some different headers, or 90° plug boots. Typically you can get away with using regular headers with the P heads though.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 4, 2009
  • Aug 4, 2009
If it is an 84 I am going to assume you have flat top pistons in which case, gt40 heads will not work. If you already have them check PTV clearance first with the cam you have. But it is most likely that they will not work.
BlownFiveLiter
18
108
Chicagoland
Aug 4, 2009
  • Aug 4, 2009
I don't believe the 84 had flat tops.
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 4, 2009
  • Aug 4, 2009
hmm mabye your right looks like they went flat top in 86, im am not sure so dont follow my advise.
black 96 gt
35
solon, ohio
Aug 4, 2009
  • Aug 4, 2009
I'm not very familiar with the pre 1987 mustangs so i'm going to have to do a little research. but if i do not have flat top pistons should the heads bolt right on? thanks for the help
BlownFiveLiter
18
108
Chicagoland
Aug 4, 2009
  • Aug 4, 2009
Yep. They'd bolt on like they came from the factory that way.
Liv2roc
42
  • Aug 4, 2009
the 84 mustang has flattops with 4 valve reliefs dont know why they say it started in 86 because I have been in three 84 stock engines and all had flattops
BlownFiveLiter
18
108
Chicagoland
Aug 4, 2009
#10
  • Aug 4, 2009
  • #10
We mean with no valve reliefs, Liv2roc.
Liv2roc
42
#11
  • Aug 4, 2009
  • #11
so is that what a true flattop is with no valve reliefs? so what are they called with valve reliefs its not dished?
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
