explorer heads on 84 mustang
black 96 gt
35
solon, ohio
I have a 1984 mustang gt with a carbureted 5.0. I would just like to know, am i going to have any problems putting the gt40 heads of an explorer on a 302 without fuel injection? If it is possible what all would i need?
Depending on if they're the GT40P heads, you might need either some different headers, or 90° plug boots. Typically you can get away with using regular headers with the P heads though.
If it is an 84 I am going to assume you have flat top pistons in which case, gt40 heads will not work. If you already have them check PTV clearance first with the cam you have. But it is most likely that they will not work.
the 84 mustang has flattops with 4 valve reliefs dont know why they say it started in 86 because I have been in three 84 stock engines and all had flattops
