Explorer Intake IAT
  • Thread starter Thread starter Slimer93
  • Start date Start date Sep 3, 2004
Slimer93
20
Vancouver WA
Sep 3, 2004
  • Sep 3, 2004
Ive got a 93 5.0 and I've put an Exploder GT40 intake on. I wanted to know what harm it would do to just leave the IAT sensor outside of the lower intake. (the explorer intake doesnt come with a predrilled location for it.)
(I sure hope its the IAT sensor and not something else, dont wanna sound too dumb
Anyway I've got a Blown setup and just wanted to know if keeping the sensor outside of the lower intake is hindering my performance potential and if there is a different way to rig it up so I dont have to remove my intakes. Thanks guys, Mike
jwzg
237
Prattville, AL
Sep 3, 2004
  • Sep 3, 2004
I believe you are referring to the ACT or air charge temp. sensor. Run a search using the terms "ACT location" and see what you come up with.
Slimer93
20
Vancouver WA
Sep 3, 2004
  • Sep 3, 2004
Thanks got it
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 3, 2004
  • Sep 3, 2004
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
