ghetto5oh said:
hey guys, i was wondering if an explorer intake from a 98 would fit on my car, i also wanna know if the elbow and tb would work on my 95 as well, i can get one real cheap and was just wondering if it would all work together and fit properly or if its too good to be true... Also what accesories would i need to get to make sure everything works ok?? Any help appreciated thanks..
As stated earlier, everything will work like a normal intake swap.
You'll need the following items for the intake swap:
GT40 upper to lower intake gaskets
FELPRO lower intake gasket set MS93334 has the blue silicon (instead of the cork) lower intake end gaskets (this has the GT upper to lower but the lower to head gaskets work with the standard GT40 intake)
Thermostat housing gasket (also recommend a new Mr Gasket 180* or 195* balanced HP t-stat)
Throttle body to elbow gasket
Elbow to intake gasket (I forget if this is a Fox TB to intake gasket)
teflon tape for the sensors that go in the intake, or you can use pipe dope.
EGR valve gasket
coolent
Oil, oil filter
dielectric grease for the distributor cap posts
PCV valve, PCV filter screen, and PCV grommet (all 3 Motorcraft preferably as some of the aftermarkt PCV valves are crap)
And for good measure I'd replace the ECT and ACT sensors if they're the stock 10 year old sensors.
Additional vacuum tubing since you may have to re-route some of your hoses to work with the explorer vacuum setup
vacuum caps to block off any unused vacuum ports (the explorer intake has a lot of them)
And of course the intake adapter \elbow if you don't have one already.
Tim
