EXTREME VIBRATION
usiskin99
26
Weston, Fl.
MY '01 GT HAS BEEN SHAKING LIKE A B*&%! LATELY, AND IM STILL TRYING TO FIGURE OUT THE PROBLEM. IT IS NOT ALIGNMENT BECAUSE I JUST GOT IT DONE A FEW DAYS AGO, AND ITS NOT A ROUGH ENGINE RUNNING. I THINK IT COULD BE EITHER THE FRONT OR REAR AXLES. ANY SUGGESTIONS? ANYONE FROM SOUTH FLA THAT COULD GIVE ME A HAND? APPRECIATE YOUR HELP!
Like caps do ya?
Anyway, need more info. Does it get worse or better with speed? Have you had any tires mounted or ballanced? Does it make any noise while shaking?
Also need you to decide whether its the front or rear, not likely its both....
well, the tires are new, but check this out. tired and pissed of it, raised the car from the rear and started looking around. the left muffler came kinda lose from the joint w the x-pipe and was hitting against the frame..... so what i did, i losened it a bit more to adjust the muffler and to make it stop hitting the frame. after doing this, i dropped the car, took it for a test drive, and voila! believe or not, the pipe hitting against the frame was making that thing shake like a rattler, and that little vibration from the muffler can actually be multiplied through the frame to make it unbearable! problem fixed! anyways, thought it was necessary to share this w u guys. appreciate the help!
thanks, and keep drivin"!
