extremely bad gas milage?
FitzC
9
i take it its not normal to get under 200km(124.274238) on a tank of gas?
i have a 86' 5.0 convertible. Its been sitting for a year or so
what could be the problem areas i should look at. so far new air filter/ oil change/ plugs + wires/ pcv
+ runs fine/ no lack of power
I agree with bullitt, I was getting 11mpg with my setup. I changed the O2 sensor last week and now I am getting about 16mpg which I think is normal for this setup. That is a combination of normal and WOT driving with mostly street driving.
If that gas sat for that long, some of it could have evaporated.
If not done already, pull codes. While O2's can cause poor mileage, so can a bad MAP sensor and a few others.
Good luck.
That's awful gas mileage. Change your fuel filter also. Add some air to all 4 corners to create less rolling resistance. Check your brakes and make sure nothing is hung up.
My pretty stock 94 Cobra gets 25MPG with some spirited driving mixed in.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
changed the o2 sensor and new fuel filter yesterday, no luck
but now however i get black smoke out the tailpipe when i rev hard
anything else i should look at, how does one go about checking the maf?
You have two choices:
1.) Dump the codes and probably find out what is really wrong.
2.) Throw parts at it, empty your wallet and get really disgusted with the car.
dumped the codes today and got
with car running
Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range - MAF VAF
and without
EVP - EGR not responding properly during test - EVP
with car running
and without
In order to give you the correct test path & fix, I need the exact code numbers.
