  • 1994 - 1995 Specific Tech
Extremely Bad Vibration...Please Help ASAP
  • Thread starter Thread starter allenpark94gt
  • Start date Start date Apr 25, 2005
A
allenpark94gt
196
allen park
Apr 25, 2005
  • Apr 25, 2005
I put in a rebuilt tranny last wk...the car has been driving fine since then...but today I took it out on the highway and at about 45-50 mph the car starts vibrating extremely bad...checked the driveshaft and all the weights were still on and driveshaft was put back on correctly....also the vibration was so bad that it snapped one of the bellhousing to motor bolts...My harmonic balancer looks fine...and I cant figure out what else the problem could be...anyone?
A
allenpark94gt
196
allen park
Apr 25, 2005
  • Apr 25, 2005
anyone?
mytight95
2,605
Dothan,Al
Apr 25, 2005
  • Apr 25, 2005
i have one that is severe about the same MPH you describe, see my thread, But mine happened upon having new u-joints installed into the driveshaft.......
jason
WHITE94COBRA
816
HUNTINGTON BEACH
Apr 25, 2005
  • Apr 25, 2005
did you get a new clutch?? if you did, did you get the right one, improperly installed, bad throw out, etc.
94-302-vert
1,947
NE CT
Apr 26, 2005
  • Apr 26, 2005
What if you leave the trans in neutral and rev the engine, any vibration? if so then run this test again with the clutch depressed... What about if you are going the 50 mph to get the vibration and you push in the clutch and let the rpm's fall... does this happen in all gears???
This can help to rule in or out things...
Chris
95strokerPSU
986
Sacramento from Philly
Apr 26, 2005
  • Apr 26, 2005
Chris
What would it mean if you're cruising in 5th till you get to the speed that vibration occurs and then depress the clutch and it makes the vibration worse?
Sorry to jack the thread.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 26, 2005
  • Apr 26, 2005
Sounds like a bad U-joint. Take the driveshaft out, and check them.
Kurt
A
allenpark94gt
196
allen park
Apr 26, 2005
  • Apr 26, 2005
took the driveshaft and got the u-joints replaced, and the shaft balanced...problem solved
CManT1914
3,172
Killeen, Texas
Apr 26, 2005
  • Apr 26, 2005
Good to hear. I had a bad vibration between 60-70, and I thought it was the u-joints (as this seems to be a common problem), but it ended up being my passenger side dump was rubbing the driveshaft. The solution? New exhaust, lol.
mytight95
2,605
Dothan,Al
Apr 26, 2005
#10
  • Apr 26, 2005
  • #10
good to hear
jason
94-302-vert
1,947
NE CT
Apr 27, 2005
#11
  • Apr 27, 2005
  • #11
How much are you guys paying for new u-joints and balancing???
I took out my dogbone yesterday and it is better but these 90mph and 100 mph things are making me paranoid...
Chris
A
allenpark94gt
196
allen park
Apr 27, 2005
#12
  • Apr 27, 2005
  • #12
I paid $118 all together for new u-joints installed, new transmission yoke, and balancing from a local driveshaft shop in my area. Not sure how much it would be where you are but from what I hear if you can find a shop that specializes in driveshaft balancing/fabricating it will be a lot cheaper then if you were to go to belle tire or something along those lines.
94-302-vert
1,947
NE CT
Apr 27, 2005
#13
  • Apr 27, 2005
  • #13
OUCH, that is half the $$ for a FMS aluminum D/S that includes all of that...
DOH.
Chris
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
  • Locked
Help please vibration in shifter at higher RPMs
  • GUNNER81
  • Nov 3, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2023
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
