Extrudehone??
  • Thread starter Thread starter tjm73
  • Start date Start date May 2, 2005
T
tjm73
2,418
Rush, NY
May 2, 2005
  • May 2, 2005
Where can this process be done? Who offers the service? I'm trying to learn the costs involved.
stang22
1,318
Washington, D.C.
May 2, 2005
  • May 2, 2005
What are you wanting to have it done to?
Tim
T
tjm73
2,418
Rush, NY
May 2, 2005
  • May 2, 2005
I've thought doing the stock intake it would make for a killer street intake on a set of Thumper heads. Would make buckets and buckets of torque and still make good hp too.
I'm all about torque.
stang22
1,318
Washington, D.C.
May 2, 2005
  • May 2, 2005
Talk to TMOSS... He is the resident intake porter here on StangNet.
Tim
9
93RiceKillinGT
60
somers Ct
May 2, 2005
  • May 2, 2005
Go to www.extrudehone.com
I believe they have a shop in PA. Cost is relativly expensive. Last time i checked the site it was about $400-$500 to do a stock intake!
Good Luck!!!
Rick 91GT
Mustang Master
95
99
PA
May 2, 2005
  • May 2, 2005
Cost us a little over $500 to have the upper and lower Cobra intake done 8 years ago. I personally would not put that kind of money into a stock intake.
We did it on our 93 Cobra to keep the look...
T
tjm73
2,418
Rush, NY
May 2, 2005
  • May 2, 2005
For $500-$600 I could buy a better aftermarket intake. I didn't think the cost would be that high. The GT-40 and RPM II are that kind of money and I know they flow the kind of numbers the Thumper ported heads flow. I'd go that route before the Extrude hone.
It's just not worth the cost at that price.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 2, 2005
  • May 2, 2005
Tim
Probally would do a equal if not better job for a lot less.
T
tjm73
2,418
Rush, NY
May 2, 2005
  • May 2, 2005
Not unless he has magic tools that can port the upper too. I'll go aftermarket for an intake.
jwzg
237
Prattville, AL
May 2, 2005
#10
  • May 2, 2005
  • #10
As Kim (moderator) once told me: you don't use pipe cleaning technology to port an intake. It does bad things to the short-side radius, which increases turbulance. (See I was paying attention, Kim ) BTW, if you are using a stock intake, the upper is not the restriction and is not so until you reach around 200 cfm/runner on the lower. That's around the maximum usable airflow on Thumper heads anyway, so save your money and send the lower to Tom Moss or port it yourself for a fraction of what what even a new one would cost and still keep your stock look.
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
May 2, 2005
#11
  • May 2, 2005
  • #11
damnnwhat kinda gains could you get from doing that to some twisted wedge heads.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 2, 2005
#12
  • May 2, 2005
  • #12
tjm - the upper isn't the bottleneck - it will flow up in the 190 cfm range (very close to Explorer/Cobra/GT40). The lower is the bottleneck. Get tmoss to open up your stock lower - with Thumpers heads that combo will work quite nicely for WAY less than the aftermarket unit. And, it will make better bottom end to boot.
F
Fatstang
Davenport, Iowa
May 2, 2005
#13
  • May 2, 2005
  • #13
Check out Tmoss website. Go to community section and read up. It is enlightening. Aftermarket intakes look cool for sure, but they are hard to justify on a performance only basis, unless you are building something pretty rowdy. Regarding the extrude honing. I am very curious how the porting is directed in a constructive manner. Not that it matters. The price is so ridiculous you might as well buy a top end manifold and have it hand ported just a bit if truly needed.
jwzg
237
Prattville, AL
May 3, 2005
#14
  • May 3, 2005
  • #14
The point is that Extrude Hone cannot be directed in any manner that defies the laws of physics. This is better stated by Kim from Corral:
Its a pipe cleaning process. Pushing an abrasive "paste" media through the pipes (of large industrial style engines and such) to remove deposits.
Anyhow, the disadvantage is that it is a fluid, very thick, but fluid and it follows fluid dynamic laws. Run a fluid through a short radius and the outer mass accelerates and the short side stalls. (You be catching where this is going) When we try to improve the flow of anything... Heads, intakes, etc... For the most part we stay away from the outside of the curve and reduce the turbulance caused at the inside of the curve to improve the flow. All extrude honing does is increase (somewhat randomly) the cross section of the piece. It does not address, and in some cases worsens that short side bend.
See the point? It woke me up too. Now I have a manifold that fits what I want it to do and don't have a lighter back pocket to boot.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
May 3, 2005
#15
  • May 3, 2005
  • #15
There are some pictures of EH runners in the Community section of my site in the Photos. I think hand porting is clearly superior - but I AM biased.
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Tensioner arm bolt
  • brandon4v
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Paint and Body Rotten moon roof trim
  • Teen'93stang5.0
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 15, 2026
Teen'93stang5.0
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
