F303 Combo
  • Thread starter Thread starter MikeROD16
  • Start date Start date Jun 23, 2008
1 of 2 Next Last
MikeROD16
Miami, FL
Jun 23, 2008
  • Jun 23, 2008
Can u guys give me a good combo to compensate with an f303 cam??
of course within reasonable price too. I have a cobra intake, 1.7 RR, and 65mm TB.
I was planning on getting gt40 heads and porting them and doing valve work, and getting longtube headers along with 1 chamber mufflers. Kinda crazy i know but i love the loud lol. Will the heads be enough, is the 1.7 RR too much? tips plz? Thanks in advance
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jun 24, 2008
  • Jun 24, 2008
1/7 RR are good. and im sending you a pm about the heads.
stykthyn
5,232
2,652
223
gainesville
Jun 24, 2008
  • Jun 24, 2008
F303 sux ballz, look for a better cam. just my $.02
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 24, 2008
  • Jun 24, 2008
You might run into some issues with the F303 and 1.7's depending on which heads you go with.
MikeROD16
Miami, FL
Jun 24, 2008
  • Jun 24, 2008
what cam do u suggest then?
stykthyn
5,232
2,652
223
gainesville
Jun 24, 2008
  • Jun 24, 2008
I would talk to anderson motorsports. they offer top notch advise and put together some killer H/C/I combos. They can tell you exactly what you need after you give them some background info.
millhouse
1,985
Simpsonville, SC
Jun 24, 2008
  • Jun 24, 2008
Based on what premise?
It works extremely well for my setup.
MikeROD16
Miami, FL
Jun 24, 2008
  • Jun 24, 2008
ok so i just called AFM and told the guy that i wanted to know what cam i should go for. i told him i was planning on going for gt40's ported, cobra intake and the other things i have. he asked me what gears will i have. i told him 3.55's and they said the cam to go with the setup i want would be a b21. all their cams are $299.
this is the descrip. for it.
[SIZE=-1]Same as B-31 except utilizing 1.7 R.R. N2O or S/C 8-15 lb 302 c.i.d. Best performer for 1.7 R.R., stock pistons and 6200 rpm. Great with TFS or Edelbrock heads. Minimum 30lb injectors and 80mm mass air. Recommend 3.55 or 3.73 gears. Good drivability down to 1900 rpm, mild idle, rpm range 2400-6200, works best with 89-93 EEC, needs 2600-3000 converter. Great N.A. cam for 94-95 Mustang with great drivability. With bolt-down R.R., needs 0.040" longer push rods.
[/SIZE]
should i go for it?? i would need to convert to MAF, and new injectors too. we r talking about a good 500-600 bucks. is it really worth it?? and thats only for those three things. i still need to buy the heads, exhaust and gears. thats a grand total of about.....a grand (give or take).
these are the specs i found in another forum
Cam manufacturer Duration lift Adv. Dur. LSA ICL
Anderson AFM
AFM B1 220/222 .490/.530 110
AFM B2 218/224 .524/.544 w/1.6 rocker 112
AFM B3 218/226 .542/.542 w/ 1.6 rocker
AFM B4 224/232 .542/.563 112
AFM B25 218/226 .544/.544 w/1.7 rocker 272/280 112
AFM B-21 218/226 .542/.542 w/1.7 rocker 272/280 112 108
AFM B-31 218/228 .544/.544 w/1.6 rocker 270/280 112 108
AFM B-41 228/236 .544/.544 w/1.6 rocker
AFM B-4R(renegade cam) 226/234 .544/.544w/1.6 294/302
AFM B451 232/240 .576/.576 w/1.6 rocker 112
AFM N2 ? ? ? ? ?
AFM N3 218/226 .542/.542 w/1.6rocker 280/288 110
AFM N4 222/230 .512/.512
AFM N6 ? ? ? ? ?
AFM N-21 219/229 .512/.512 w/1.6 rocker 110
AFM N-41 222/232 .512/.512 w/1.6 rocker 110 106
AFM N-51P 228/238 .499/.4976 w/ 1.6 rocker 110
AFM N-61 228/236 .544/.568 w/1.6 rocker 110
AFM N-71 232/240 .576/.576 110
AFM N-81 236/244 .568/.576 110
AFM N-91 240/248 .576/.576 110 106
AFM N111 248/258 .576 ? ? ?
[SIZE=-1]
[/SIZE]
MikeROD16
Miami, FL
Jun 24, 2008
  • Jun 24, 2008
forget the specs i put up, those arent right. i called and the guy said that its custom lift according to what i have.
stykthyn
5,232
2,652
223
gainesville
Jun 24, 2008
#10
  • Jun 24, 2008
  • #10
every N/A setup I have ridden in with an F303 has let me down, especially if it's in a daily. they have all fallen flat on their faces off the line and if you are driving stop light to stop light they make life miserable.
The only car that I have been in that responded well to the cam had a vortech s trim on it.
they do sound mean though.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 24, 2008
#11
  • Jun 24, 2008
  • #11
I had an E cam, GT40 heads, unknow roller rockers, Cobra upper and lower and 24 lb injectors in my 91 GT I used to have and it sounded mean, and was fast. The only thing holding it back was the AOD trans. That thing felt so slow unless I did the AOD shuffle.
MikeROD16
Miami, FL
Jun 24, 2008
#12
  • Jun 24, 2008
  • #12
lol, yeah i before all this, i need to get my transmission fixed. grinding gears suck. and now to add to the odds and ends, a rocker arm keeps coming loose.
thats on my to do list.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 24, 2008
#13
  • Jun 24, 2008
  • #13
+1 i love my f-cam seems to make good power with my combo.... the F cam seems like a better blower/turbo cam than a N/A cam....
millhouse
1,985
Simpsonville, SC
Jun 24, 2008
#14
  • Jun 24, 2008
  • #14
There is no doubt about that...but I ran around on the f-cam and my h/c/i setup only for a few weeks and it absolutely screamed! At that time I still had the 3.73's....and it just felt great.
1SickFox
#15
  • Jun 25, 2008
  • #15
Ha not to be captain obvious, but it is designed for a blower. For whom ever said it sucked, your nuts. It works awesome with a power added, and also has great street manners. It also sounds sick, specially with a blower.
331fastcoupe
9
#16
  • Jun 26, 2008
  • #16
I built a motor , used the f- cam , cobra intake , stock e-7's slightly ported myself ,1.6 rr stock block and pistons a real buget motor. Here were the #'s 260 rwhp n/a the guy at the dyno said that was very good and thought it was higher than most e- camed cars he ever dyno'ed.
The next time I dynoe'd it I had a blower on it just a vortech a trim @ 7lb's it made 340 rwhp.
I thought it was amazing.
MikeROD16
Miami, FL
Jun 26, 2008
#17
  • Jun 26, 2008
  • #17
what do u think about the x303?? ive seen good reviews on it. but is it drivable on heavy traffic?
joel5.0
429
Puerto Rico
Jun 26, 2008
#18
  • Jun 26, 2008
  • #18
Before you consider any of the cams mentioned so far, you need to change the SD system to MAF..... just a thought.
MikeROD16
Miami, FL
Jun 26, 2008
#19
  • Jun 26, 2008
  • #19
yeah i know, i found a site that specializes in all that. but i dont want to pay 200 somthing bucks. im probably going to look for a computer and harness at the junkyard. Just a random question, but does it have to be the computer and
harness from a 5.0 mustang? any other cars i can take it from? and how about a 4cyl mustang? theres quite a few at the junkyard by my house.
joel5.0
429
Puerto Rico
Jun 26, 2008
#20
  • Jun 26, 2008
  • #20
You can even use your existing harness and just add the additional wires for the MAF, VSS and FPM circuits as explained at http://www.stangnet.com/tech/maf/massairconversion.html .... look for a scrapped ECM connector (to take pins and wires from), VSS and MAF pigtails, more wire, soldering iron and time.
1 of 2 Next Last
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
