I have a 94 lighting with the e4od that has a mustang a9m mass air computer and a baumnan trans controller for the e4od. My current set is as follows. F4te 94 block with 10:1 forged Pistons, stock crank and rods with arp hardware. E303 cam comp pro magnum 1.6 stud mount roller rockers Windsor jrs heavily ported and polished intake to a 1262 and exhaust to a 1450 exhaust gasket. Gt40 upper and lower and the lower just has the ports cleaned up a bit. 30 lb injectors pro m 80mm mass air Kirban adjustable regulator. Stock 65 mm throttle body, Mac equal lengthy shorties into 2 1/2 exhaust without cats. 4.10 gears factory tech 2400 stall converter.msd tfi coil and 6al box. I know it's on the mild side with the e303 cam and the gt40 limiting power over 5k. It is very fun to drive though and runs great. Just wondering what anyone thinks it's makes as it sits before I get it tuned on dyno I have a sct 4 bank chip I'll install so I can have a few tunes saved on it. Timing is set at 14 right now.
My buddy has a 351w typhoon efi intake (performer rpm knock off)that's got some port work done to clean up the ugly port as it came.he is willing to let me throw in on and dyno it to see how it works compared to the gt40. I also have a brand new f303 I was thinking about installing and though it would match that intake better then the e303and would make more mid range and top end. I know either cams are not optimal in a heavy truck but the e works pretty darn well for what is it I would just like to get the most power out of it with the parts I have. Also recently acquired the x303 that's why I was curious of the 3 which would work the best
