Fabricating bumpers.... making exhaust cutouts. (read this!!. thanks)
95CobraStang
281
Chico, CA
This is hard to explain
I want to take a bumper without exhaust cut-outs, and put them in. However, I do not want to just cut it out and leave it at that. I want to have it angle in and have a finished and clean look to it.
How hard is it to work with the bumper material and add on to it? This is a little project that I want to take on, and if it is doable, then ill do it. I think the finished project will look really nice!!!! I guess at the very least, I could take really thin metal, bend and cut it into the shape im looking for and slide the bumper in to it....i'd rather not, though.
I circled the angled finished look that i was talking about right here:
By the way, I'm not talking about turning a v-6 bumper into a v-8 bumper...it's a little different than that.
Any help would be greatly appreciated!!!!! This will be fun if it works
this would be tite for a center exhaust and a V6 bumper
other than that i can't imagine what would need something like that... aside from the earlier Sn95's
My guess is you would need to have at least two bumpers or one bumper and a lot of body filler....
I would say to take the "donor" bumper and cut out those cut outs and leave a good amount of the rest of the bumper around the cutout for cutting/trimming/blending and then cut a small area where you'll want the cutout to go and then decide on placement, trim to fit, and then blend/fill it in... prime and paint.
You can do it no problem.
When my car was getting flamed at Santini's, some import car was in for a magazine (tech) shoot doing essentialy what you desire.
They took a Corvette bumper cover as a donor and patched a couple of pieces on to the import car's bumper using a binary polyurethane epoxy material. It was dispensed from what looked like a caulk gun that had the two tubes of material (urethane filler / catalyst) that was manually pressured and then mixed in the tip. The bumper material was "roughed" up a grinding disk and applied with a tape that looked like drywall tape for better bonding of the material. The quickly drying material was applied and spread about. 5-10-minutes later it was ready to be grinded and sanded down, then prepped for paint.
I was impressed enough to order a Cobra bumper on the spot so that the letters could be filled, painted and installed along with all the other paint work I was having done.
You can see my filled bumper by using the link in my signature to my SoundDomain sight.
Hop
