Fabrication Parts - Vibrant Coupling, Exhaust Pipes, Flanges and more
statRacing
Fabrication Catalog
Megan Racing Intercooler
Megan Racing Muffler
Vibrant Exhaust Fabrication
Vibrant Catalytic Converter
Vibrant Flat Black Muffler
Vibrant Resonators
Vibrant U-J Exhaust Piping
Vibrant Straight Exhaust Piping
Vibrant Exhaust Flex Section
Vibrant Manifold Flange
Vibrant Exhaust Flange
Vibrant Exhaust Gasket
Intake and Turbo Fabrication
Vibrant MAF Adapter
Vibrant T Bolt Clamps
Vibrant Worm Gear Clamps
Vibrant Boost Brace
Vibrant Breather Filter
Vibrant Aluminum Piping
Vibrant Silicone Coupling
Vibrant Intercoolers
Vibrant Turbo Flanges
Metal Core Race Catalytic Converters
3 inch flat black mufflers
3 inch stainless steel resonators
Stainless and Aluminum exhaust and intercooler piping
Turbo Flex Sections
Honda and Acura Exhaust Manifold Flanges
2 bolt and 3 bolt stainless exhaust flanges
MAF adapter to build your own intake kit
Silicone Coupling of all colors and sizes
Stainless T Bolt Clamps
Yonaka Motorsports Intercoolers and Intercooler Cores
Our intercooler cores are available in the following sizes without endtanks. These are ideal for custom turbo applications which require unusual outlet positions.
get_image.aspx
$179.99
Order here: Yonaka Intercooler
YMIC0C1
This intercooler is bar and plate core only, no end tanks are included.
Dimensions:
- 100% aluminum
- Bar and plate design
- Size: 22" long x 9" high x 3" thick
Performance:
- Supports more than 550 hp.
- Flows up to 800 cfm.
Application: Designed for use in any custom or upgraded stock turbo setup. It is perfect for any big-boost application for Nissan, Toyota, or Mitsubishi.
get_image.aspx
$219.99
YMIC0C2
This is the intercooler core only, no end tanks are included.
Dimensions:
- 100% aluminum
- Size: 26" long x 12" high x 3" thick
Performance:
- Supports more than 650 hp.
- Flows up to 900 cfm.
get_image.aspx
$269.99
YMIC0C3
This is the heart of our "Monster" intercooler. Complete bar and plate core only, no end tanks are included. Perfect for custom applications.
Dimensions:
- 100% aluminum
- Size: 26" long x 12" high x 4" thick
Performance:
- Supports more than 1000 hp.
- Flows up to 1350 cfm.
get_image.aspx
$399.99
YMIC012
This is our largest bar and plate front mount intercooler with end tanks. It is the biggest, baddest intercooler ever made. We simply call it "The Monster".
With a 4" thick bar and plate core that is over 2 feet long, this intercooler can flow enough cfm to support 1000hp! This intercooler is most popular with large horsepower applications such as single turbo Supras, RX-7s, Skylines, and race-only Honda applications.
Dimensions:
- End to end length with tanks: 33"
- Core Size: 26" long x 12" high x 4" thick
- Inlet/outlet diameters: 3"
Performance:
- Supports up to 1000 hp
- Leak tested at 30 psi
Application: Designed for use in large flow requirement custom turbo setup. It is perfect for any big-boost application for all types of vehicles. Small street turbos need not apply!
get_image.aspx
$249.99
YMIC010
This is a full aluminum bar and plate intercooler with polished cast end tanks. This intercooler is out most popular size for 1G/2G Mitsubishi Eclipses, as well as turbocharged Honda B18C/H22A platforms. Perfect for your DSM, Honda, Nissan or other custom turbo project.
Dimensions:
- End to end length with endtanks: 29"
- Core Size: 22" long x 9" high x 3" thick
- Inlet/outlet diameters: 2.5"
Performance:
- Supports up to 550 hp.
- Leak tested at 30 psi.
Application: Designed for use in any custom or upgraded stock turbo setup. It is perfect for any medium to big-boost application for Nissan, Toyota, Honda or Mitsubishi.
get_image.aspx
$299.99
YMIC011
This is a full aluminum intercooler with end tanks. Popular for large boost applications for most turbocharged imports.
Dimensions:
- End to end length with endtanks: 33"
- Core Size: 26" long x 12" high x 3" thick
Performance:
get_image.aspx
$179.99
YMIC006
This is a full aluminum intercooler with polished cast end tanks.
Dimensions:
- End to end length: 26 inches
- Core Size: 18" long x 9" high x 2.5" thick
Performance:
- Supports more than 350 hp
- Flows up to 500 cfm
Application: Designed for use in any custom or upgraded stock turbo setup. It is perfect for any big-boost application for Honda.
get_image.aspx
$169.99
YMIC009
Dimensions:
- End to end length with endtanks: 26"
- Core Size: 18" long x 6" high x 2.5" thick
Performance:
- Supports more than 275 hp
- Flows up to 350 cfm
