Factor. I dont know but would like to find out what factor means
Might not be the Answer:
Per Jegs:
Flat tappet camshafts can only withstand so much valve spring pressure pushing the lifter against the cam lobe. Cam Lobe ... This is a limiting factor when compared to a roller setup. ... arm ratio. More cam lift means the valve will open further.
91-95:
Lift: .278 intake, .278 exhaust
Duration: 276 intake, 266 exhaust
Overlap: 39 degrees, 19.51 factor
Lobe Center: 116 intake, 115 exhaust
he is asking about the meaning of: 19.51 factor in the overlap line above
