Factory gauges
I want to make my factory oil, amp, and temp gauges to work. Can I use generic sending units or do I need specific ones? I found the ones on California Mustang for about $30 but I don't know if some ones off a 5.0 would work. Also, what does it take to make the amp gauge work? Thanks
I'm pretty sure they're set to read from the original design sensor which may be a different ohm than the 5.0 gauges. You can get replacement sensors (water, oil) from your local parts store for your car (O'Reilly's gets mine next day in Standard brand for me). If none of your gauges are working I might suspect your instrument cluster VR on the back of the cluster. You could check the wire going to the gauges with a meter to see if a signal is being sent to them at the VR and if any signal is coming out of the VR.
http://www.mustangsunlimited.com/itemdy00.asp?T1=GR508+01
Jon
Ok, you lost me, so you have some aftermarket gauges hooked up and the stokers disconnected? Need more info. on your setup. What are the aftermarket ones - electrical or mechanical water, oil and volt or amp? I think you're going to need to run dual sending units to run both I'm guessing.
Jon
If you want the stock gauges to work, then get the stock replacement sending units from a Mustang shop. If you have a other than stock intake, you may need the other size temp sending unit. There are 2 common sizes.
As for the instrument cluster voltage regulator, get an electronic one or you can also make your own. The replacement ones are usually junk.
The 66 gauges (fuel, oil, and temp) are powered by the CVR on the back of the instrument panel, which actually supplies a pulsing 7V IIRC. Each is grounded through appropriate sensors, which vary in resistance to change the indication.
The AMP requires divine intervention, or an hours' work. You must disconnect and clean EVERY CONNECTOR between the gauge and the alternator. Pop them apart, clean the living H out of them with Q-Tips, an old toothbrush, and Brasso. Then grease them lightly with silicone grease, such as Ford's D7AZ-19A331-A.
