Just went in for emmisions today, only test I passed was the gas cap test.
Anyway, the CO emmisions were pretty close, the limit is 15.0 - I had a 15.3. But the hydrocarbons part didn't work out so well. The limit was 0.8 and I scored a 3.90. Guess this means I'm running 5x too rich.
The car is pretty much stock as far as the motor is concerned. However, I have longtubes and an offroad H pipe (No smog pump hooked up). I've heard of other people passing with this setup so I figured I'd give it a shot.
What I didn't know was that I can only take the test ONE more time -- those bastards, and I'm gonna have to get some receipts before I can even do that.
So I'll probably have to go buy a catted shorty H pipe first off (temporarily anyway). But I'm trying to figure out what else I should do. From what I've heard the smog pump doesn't do that much for you anyway, anyone know for sure? Also, does pouring isopropyl alcohol with your gas really help with anything? I thought I could take the test as many times as I wanted, so I was just gonna mess with it until I passed -- but now I dont know what to do
Also, with the new pipe on -- should I go take emmisions right away after installation or will that mess anything up?
Anyway, the CO emmisions were pretty close, the limit is 15.0 - I had a 15.3. But the hydrocarbons part didn't work out so well. The limit was 0.8 and I scored a 3.90. Guess this means I'm running 5x too rich.The car is pretty much stock as far as the motor is concerned. However, I have longtubes and an offroad H pipe (No smog pump hooked up). I've heard of other people passing with this setup so I figured I'd give it a shot.
Where did you find this info?
