  • SN95 4.6L Mustang Tech
Failed Inspection! Error code!
  • Thread starter Thread starter joshheat25
  • Start date Start date Nov 16, 2004
joshheat25
871
Delaware
Nov 16, 2004
  • Nov 16, 2004
I failed inspection today for two error codes that I looked up online and it said that my "system was too lean in bank one and two".
does anyone know how to fix this I was assuming that I should use a higher octane I have and air intake and exhaust maybe I should use 93.
6Stang7
1,470
Livermore, CA
Nov 16, 2004
  • Nov 16, 2004
Too lean means that you don't have enough fuel in your air/fuel mixture. The octane rating has nothing to do with the problem. It's impossible for me to tell you what is causing this problem because there are way too many things it could be. Bad O2 sensor, bad MAFS, dirty injectors, ect. I assume you are talking about smog here, so can you post your outputs (hydrocarbons, NOXS, CO2)
F
fiveofanatic
How to fuel a Mustang:
8,152
Phoenix, AZ suburbs
Nov 16, 2004
  • Nov 16, 2004
Moving to tech....
What are the code numbers? What year car? (I assume it's a 4.6 Mustang.)
If it's '96 or newer it probably isn't the o2's, they've got their own codes. Lots of times it's vacuum leak(s) or a dirty/bad mass air meter.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 16, 2004
  • Nov 16, 2004
theres a common problem on fords where both the front O2 sensors show lean or rich, than you should check the Mass Airflow Sensor. also if you have a K&N air filter, it might be overoiled and that would gunk up the MAF.
joshheat25
871
Delaware
Nov 16, 2004
  • Nov 16, 2004
2000 Mustang GT The codes were P0171 and P0174 Which are both System to lean in Bank 1 and then in Bank 2 what ever that means. I have decided it isn't the injectors because I just recently put injector cleaner and it has had this prob before. It might be the MAF is dirty or maybe a Vaccum problem around the intake plenum I am going to spray carb cleaner around the opening while the engine is running to determine whether this is the case.
joshheat25
871
Delaware
Nov 16, 2004
  • Nov 16, 2004
I also was wondering if anyone had any ideas of what to do to quiet down my exhaust for the db test just a fix.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 17, 2004
  • Nov 17, 2004
what do you have for exhaust? and if you spray carb cleaner around the plenum you arent gonna go near your MAF. use electrical contact cleaner on the MAF, DO NOT USE CARB CLEANER ON YOUR MAF.
6Stang7
1,470
Livermore, CA
Nov 17, 2004
  • Nov 17, 2004
Do you have a copy of the test results?
F
fiveofanatic
8,152
Phoenix, AZ suburbs
Nov 17, 2004
  • Nov 17, 2004
Bank 1 is the pass. side of the engine, bank 2 is the driver's side. All data gives a couple of possibilities:
Fuel system:
*leaking/contaminated injectors
*leaking fuel press. regulator
*low fuel pressure or running out of fuel
Induction system:
*air leaks after the mass airflow meter
*vacuum leaks
*PCV valve/line leaks
*improperly seated dipstick
EGR system:
*leaking egr gasket
*stuck egr valve
*leaking diaphragm
Base engine:
*oil overfill
*cam timing
*cylinder compression
*exhaust leaks near or before the o2's
Personally, I lean towards vaccum or PCV leaks, or bad mass airflow readings. It's happening on both banks of the engine, so it's something that affects the whole engine, probably not something like an injector. Unmetered air entering the engine from a leak I would say is going to be more likely vs. a fuel delivery problem, though it could be fuel.
Pitch4pd
235
Allentown
Nov 18, 2004
#10
  • Nov 18, 2004
  • #10
It could also be as simple as a computer update from ford. But I wouldnt do that first, if it is doing it on both sides I would try to ruleout the o2's they normaly go one at a time, odd to have em both go. Like everyone is saying check the maf, make sure it is cleaned out (use the proper stuff). You could just reset your computer, drive it for two weeks and hope the codes dont get set before you go back.
Charles
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
